Old 06-01-2018, 07:36 PM   #1
Macdaddy1
Cleaning Rear Differential
Is it ok to spray brake cleaner on my rear diff to clean them before installing the cover and new gasket?
Macdaddy1 is offline   Reply With Quote
Old 06-01-2018, 08:16 PM   #2
mongocanfly
Re: Cleaning Rear Differential
are you talking about the carrier and r&p?or just the diff cover?....I use brake cleaner as a parts cleaner all the time....evaporates quickly
Mongo...aka Greg
1981 c30 lq9 nv4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598
1955.1 ls3 tr6060...(under construction)(on hold)
2013 gmc z71. (daily driver)
Old 06-01-2018, 08:21 PM   #3
Killer Bee
Killer Bee's Avatar
you can wipe the flange and inch or so of the inner housing with brakleen on a lint free cloth, it will dry quickly..
or spraying just the flange and blowing a little low pressure shop air will work..
I wouldn't sweat a little overspray but I wouldn't deluge it where any elastomers like pinion seals or air/elec locker components could be affected..
make sure to clean bolt holes really good, leftover oil in there can squeeze out across seal area when tightening bolts..
If you're having trouble keeping oil from dribbling down the lower edge, you can jack up the rear end so the oil stays up forward until cover is set and secured..
you can also spread a small bead of grease along the low places to hold oil back..
good luck!
now, waiting for gasket vs rtv argument to start in 3... 2.. 1.
Killer Bee is online now   Reply With Quote
Old 06-01-2018, 08:32 PM   #4
Macdaddy1
I was talking about the carrier and R & P. I am ordering a new cover and gasket. Just wanted to clean the inside before assembling but did not want to damage anything with the brake cleaner.
Old 06-01-2018, 08:59 PM   #5
Macdaddy1
Also where is the silly fill hole?
Old 06-01-2018, 09:12 PM   #6
PGSigns
PGSigns's Avatar
On the right side about half way up and about 5 inches behind the pinion. I don't spray a bunch up inside.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 06-01-2018, 10:32 PM   #7
Macdaddy1
OK located it thanks. The passenger side axle has a code HA 216 W does anybody know what that refers to. I can't find anything on the web.
Old 06-01-2018, 11:04 PM   #8
Killer Bee
Killer Bee's Avatar
what's your question? what axle you have? or just what those numbers mean?
can you post a picture(s)? either way it'd be a lot easier if we all knew what axle it is..
I posted some Dana stuff here http://67-72chevytrucks.com/vboard/s...48&postcount=8
there's a chart in there and many other places on the interwebs to help you identify it..
Old 06-02-2018, 10:23 AM   #9
Macdaddy1
Killer bee
I was trying to ask what axle this has and whether it might be posi. I will take some pics later today.
Old 06-02-2018, 12:25 PM   #10
mongocanfly
the codes on the outside of the axle won't dictate what's in the housing ir what's been swapped over the yrs....pics would be best...but if you look in the carrier and can see the side gears ,cross pin, and bevel gears its a open diff......this is a open diff...
Mongo...aka Greg
Old 06-02-2018, 12:34 PM   #11
mongocanfly
this is a g80 locker.....
Mongo...aka Greg
Old 06-02-2018, 07:20 PM   #12
Macdaddy1
Thanks Greg
I took the rear diff cover off and found out it has 3.73 gears and no posi. I needed to replace the pinion seal and had a beast of a time trying to break it loose but I finally got it. I think I better order a new pinion nut though. Hey Greg, When you get time you you please take a pic of your zbar linkage. I just got the bracket from advanced adapter but I am not sure it will be long enough. If i could see yours it would really help.
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
