Old 06-07-2018, 10:49 AM   #1
andyh1956
Cam Break In
I am about to fire up a fresh engine & has a new Comp Cams 268H in it. I was reading the instructions & they tell me to REMOVE the inner valve springs I installed from the kit to break the cam in & then re-install them after break in. Holy Swaparama Batman!
Do any Yall do this with a new cam? I have the cam lubed up & additive in the oil & engine is pre lubed.
andyh1956 is offline   Reply With Quote
Old 06-07-2018, 11:51 AM   #2
toolboxchev
Re: Cam Break In
Comp Cams is a great company to work with, unparalleled customer support. The one thing I have learned on this site from a select few is something Comp will not inform you of.
Their lifters are great, yet one detail is left out. Take apart the lifters prior to install and clean them in a solvent. The protective oil they put on them will attract dirt. Its just an extra step to insure they all function properly. Coat them with the proper break in oil such as their product or something formulated for Flat Tappet lifters such as Valvoline VR1. It has the proper ZDDP compounds plus, most importantly, a high film strength.
Assemble as usual and you should have no problems. The step above is just to make sure non of the lifters have any sticky spots or debris to clog up your engine.
And YES follow all of their other recommendations! I most likely will be using their products again to put together another build here in the very near future.
toolboxchev is offline   Reply With Quote
Old 06-07-2018, 12:24 PM   #3
andyh1956
Re: Cam Break In
So you DID remove your inner valve springs & re install them after cam break in?
Old 06-07-2018, 03:35 PM   #4
mattfranklin
mattfranklin's Avatar
Re: Cam Break In
My machinist took a different approach on that one. He set me up with two sets of Crane valve locks (keys or whatever you want to call them). One set had the spring 0.050 longer than stock. The other set had the spring 0.050 shorter than stock. He instructed me to break it in with the long (tall) set and after break in to switch to the short set for full rev potential. He said it would be a pretty quick process and had a lever tool I could borrow to swap locks with the heads still on the truck. I'm in the process of assembling right now, so we'll see how that goes.
Another machinist friend said that he had a special set of rockers for break-in only with like a 1.3 ratio or something like that.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is offline   Reply With Quote
Old 06-07-2018, 03:43 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Cam Break In
Having the higher spring pressure of a dual spring could cause premature cam and/or lifter failure. Even after break in... so yes... remove the inner springs.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
GASoline71 is offline   Reply With Quote
Old 06-07-2018, 10:46 PM   #6
YoungPup1977
YoungPup1977's Avatar
Re: Cam Break In
Its work, some times it takes time and effort to end up with something that works properly by abiding by the experts/design recommendations on "breaking in" a camshaft....if you do not follow the instructions/recommendations and you have issues, most likely they will not stand behind your mistake....
YoungPup1977 is offline   Reply With Quote
Old 06-08-2018, 12:07 AM   #7
andyh1956
Re: Cam Break In
Thanks. Keep yall posted.
Old 06-08-2018, 12:15 AM   #8
Captainfab
60-66 Nut
Re: Cam Break In
With the 268H cam you should not be running dual valve springs, so removing the inner springs would not be necessary. You should be running the 981 springs. But you can always call comp's tech line to verify.
Old 06-09-2018, 07:48 PM   #9
andyh1956
Re: Cam Break In
I have not provided Yall with enough information. The engine is a 302 Ford & the springs that came in the kit are inner / outer.
Sorry
I think I am gonna build me a set of adapters & run this engine on my test stand for break in & then install the inner springs before we install the engine in the car. It goes in a '69 Mustang Fastback.
Old 06-09-2018, 11:56 PM   #10
mattfranklin
Re: Cam Break In
Sorry
Sounds like a cool project.
Old 06-10-2018, 12:21 AM   #11
YoungPup1977
Re: Cam Break In
Sorry
Its not good to use the F word in this chevy forum....just sayin....
Old 06-10-2018, 10:22 AM   #12
68gmsee
Active Member
68gmsee's Avatar
Re: Cam Break In
However, since it's for a 69 Mustang he's forgiven. My brother had one and it was one hell of a vehicle. Ran like a scalded ape..
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 06-10-2018, 06:26 PM   #13
toolboxchev
Re: Cam Break In
[QUOTE=andyh1956;8276741]So you DID remove your inner valve springs & re install them after cam break in?[/QUOTE
No I did not, I wish I would have though, would have cleaned the lifters also, had I known at the time.
My top end rebuild is still running although I am in need of doing the bottom end now, so looking at a complete rebuild or crate motor.
Old 06-11-2018, 10:57 AM   #14
andyh1956
Re: Cam Break In
We installed a Comp Cams Camshaft for a TPI in our TBI K5 engine yrs ago & didn't do anything different than crank it up & start driving it & it still runs fine. But as expensive as things are now I want to take every precaution available!
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
