Old 06-09-2018, 08:43 AM   #1
old51sedan
old51sedan's Avatar
Question MI: Ralley Wheel Paint
Just curious as where to buy the silver paint for these wheels, (Argent Silver) I believe it's called. I have a couple sets of these, one of which I'm going to install on my truck. One set has silver on the back side and the other the wheels are painted silver front and back. Do you believe these were painted that way, maybe from different plants? I know I could have some mixed, but would rather buy it in a rattle can. Even close, doesn't need to be exact.
old51sedan is offline   Reply With Quote
Old 06-09-2018, 08:54 AM   #2
rideair
Re: MI: Ralley Wheel Paint
I purchased my paint from Eastwood, they offer the correct color paint, and a additional clear coat. I found my wheels were black on the backside, silver sprayed on the front, with over spray through the holes.
rideair is offline   Reply With Quote
Old 06-09-2018, 09:07 AM   #3
old51sedan
old51sedan's Avatar
Thanks for the reply. I'm sure they were painted different at different factories. Curious, did you paint just the front? I wondering how many cans it would take to do 5 wheels.
Old 06-09-2018, 11:26 AM   #4
blindbug
Duplicolor HPW101 Silver works great. Get (2) cans of primer, (2) cans of the base silver, and (1) or (2) cans of gloss clear coat. The rear of the wheel should be black. The 'base' of the center cap is supposed to be the same silver as the wheel, though I actually polished the whole center cap when I did mine. I used Duplicolor wheel paint (which should stand up to the chemicals a little better).
The steps I used:
  1. Cleaned the wheels with a pressure washer and some degreaser.
  2. Removed the wheel weights and sanded with 220 grit sandpaper with particular focus on rust spots and pitted areas. I sanded until I could close my eyes and run my hand across it without feeling any transition.
  3. Cleaned the wheel with mineral spirits and sanded again, making sure it was smooth. It's ok if you reach bare metal.
  4. Cleaned the wheels and the tires with mineral spirits and masked the wheel from the tire.
  5. Cleaned the wheel one last time with a tack cloth and mineral spirits.
  6. 2 light, and then 1 medium coat of wheel primer, allowing 10 minutes between each coat
  7. 15 minutes after the primer, 3 light coats then 1 medium coat of base color with 10 minutes between each coat.
  8. 15 minutes after the base, 2 light coats then 1 medium coat of gloss coat with 10 minutes between each coat.
  9. Waited a day or 2 before crying while putting on the beauty rings, which scratch up all your had work.
Good luck!
blindbug is offline   Reply With Quote
Old 06-09-2018, 05:21 PM   #5
Gotenntitans
Gotenntitans's Avatar
Those look really good. Worth all the effort you put into them.
GoTennTitans
1987 GMC Sierra
1990 GMC Sierra
2010 Chevy Silverado 4x4
Gotenntitans is offline   Reply With Quote
Old 06-10-2018, 10:12 AM   #6
Pontiac1976
Pontiac1976's Avatar
Great job on the wheels. Yes plants some maybe frosted on the out side edges in side edges on the back. I think it the set up on how they got painted or manger at the plants
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 06-10-2018, 05:18 PM   #7
old51sedan
old51sedan's Avatar
Thanks for the information not only on the type of paint, but on the painting of the wheels. Your wheels look great, & yes putting the trim ring really hurts. Speaking of trim rings has anyone actually bought any of the repos. I have 15X6.5 wheels and trying to find nice used set is almost impossible. I'm thinking 2-1/2 should work. Anyone know where to buy a set? Thanks again for the help.
Old 06-10-2018, 05:43 PM   #8
rideair
Here's a pic of mine after painting them with the Eastwood paint, and adding the cheap plastic caps and trim rings (stainless) off ebay.
Enjoy,
Old 06-10-2018, 06:28 PM   #9
old51sedan
old51sedan's Avatar
Nice Suburban, the wheels look great also. I have nice original center caps, just want a nice set of rings. May buy a set off eBay. Thanks
Old 06-11-2018, 08:01 AM   #10
Keith Seymore
Keith Seymore's Avatar
They should be silver on the front and black on the back, with silver overspray through the holes.
K
(photo #12): http://www.73-87.com/7387info/Assembly%20Line.htm
Chevrolet Flint Assembly
1979-1986
1986 - Present
Old 06-11-2018, 11:27 AM   #11
Bandit130
Bandit130's Avatar
I used this to paint my grill last year. If I was painting rally wheels I would use this too. From AZ.
1974 Cheyenne 10 LWB 350/TH350/AC/4 BBL Quadrajet.
Bandit130 is offline   Reply With Quote
Old 06-12-2018, 12:00 AM   #12
1774btcrew
1774btcrew's Avatar
the eBay rings look good but are REALLY flimsy and flex a lot when you go to install them. I still plan to buy a couple more sets though as I have a few sets of wheels I plan on selling
1977 Crew Cab Shortbed with 4BT Intercooled Cummins Diesel and a 4L80E
AZPartsLocators on Instagram
1774btcrew is offline   Reply With Quote
Old 06-12-2018, 08:15 AM   #13
old51sedan
old51sedan's Avatar
Thanks, I have plenty of time to look for a set.
Old 06-12-2018, 10:16 PM   #14
3drburb
The steps I used:
Good luck!
Great information on the prep and painting.
3drburb is offline   Reply With Quote
Old 06-13-2018, 08:49 AM   #15
rideair
The eBay stainless rings are "VERY" flimsy, you must be very, very careful when putting them on. I ended up putting kinks in two of mine (got the company to replace them for being so cheap). The problem is the tabs that hold the rings in pace at bent out a little to straight. I just squeezed the tabs in a bit to make them fit better, and no problems were had.
Old 06-13-2018, 09:13 AM   #16
blindbug
Thanks. I'm definitely an amateur / shade tree mechanic, at best. Sometimes it's hard to get intimidated by junk like this, but its often all for naught. It's really about just tearing into things and seeing what works.
I actually painted (1) of the wheels and didn't like the end results, so I waited a week for the paint to cure and then sanded the wheel down and did it again. My mistake the first go round was using a wire wheel on an small angle grinder to removed the rust in places. It caused a bunch of ridges that showed up after painting. By hand sanding, it took a long time and my hand was sore, but gave me much better results. Plus, I could sand the wheels late at night after the kids were in bed without waking them up.
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
