Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 06-10-2018, 06:59 PM   #1
panhead59
Hei dbl check ?
I know this has been covered to death but i just want to make sure. I m changing from points dist. To hei dist. I ve disconnected yellow wire from starter. Taped up yellow wire that used to go to neg. Side of coil. Ran correct gauge new wire from hei dizzy to fuze block. All correct ?
"You are not forgotten" USMC 75-79 (Aviation Ordnance Tech- F-4 Phantom)
1959 H-D Panhead. Owned since 1978. Currently with son in Lawton, OK.
1968 Chevy Custom SWB pick up. Fleetside. Lowered 2/4. Totally refurbished. 1966 Pontiac GTO. 4 speed. Saved original 389. Now has slightly built 455 engine. 355 rear gears. Very fun to drive|!|!|! 2015 Chevy Camaro SS. It'll outrun the Goat !||!!||!
panhead59 is offline   Reply With Quote
Old 06-11-2018, 12:58 AM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Hei dbl check ?
You will want to run the wire to the IGN UNfused terminal on the fuse panel, which is fed by the ignition switch with key on. A 12 gauge wire is recommended.
you meant the yellow wire went to the positive side of the coil.
Here is a very nice alternative to wiring to the fuse panel as it directly replaces the ignition wire from the key switch to the ignition coil.
http://67-72chevytrucks.com/vboard/s...d.php?t=708975
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 06-11-2018, 07:54 AM   #3
panhead59
Re: Hei dbl check ?
Yes sir. Thank you. Just wanted confirmation before i burnt up a new dizzy. Should be starting new 350 next weekend. Finally.
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
