Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Welcome and Discussion > General Discussion
Old 06-11-2018, 01:03 PM   #1
70GMCer
70GMCer's Avatar
Note To Self
Note to self: Always remove the jack stands out from under the rear end before taking truck for a test drive.....
I go and get in the truck to leave...put the truck in gear & truck does NOT move..I forgot I had the truck rear up on jack stands.
In all the years I've worked on vehicles, I have NEVER did that....DUH !!!
My age is catching up with me.....lol
Maybe I should take up "needle pointing"
1983 Silverado Short
1963 Chevy Impala
70GMCer is offline   Reply With Quote
Old 06-11-2018, 01:13 PM   #2
andyh1956
Re: Note To Self
Originally Posted by 70GMCer View Post
Note to self:
You'll poke your eye out!
The best mechanic I ever knew was my Grand Daddy. Once in high school I saw him change oil in his LTD & forgot to re-install the drain plug. I was shocked & couldn't figure how he could have let that happen.
I KNOW now, we all got it comin...
andyh1956 is offline   Reply With Quote
Old 06-11-2018, 01:14 PM   #3
70GMCer
70GMCer's Avatar
Re: Note To Self
Originally Posted by andyh1956 View Post
you'll poke your eye out!
hahahahahaha
1963 Chevy Impala
Old 06-11-2018, 03:42 PM   #4
xrcr
Re: Note To Self
we did that to a buddies truck in the mall parking lot. Just high enough so tires were off. Then we sat and waited... He thinks it was funny, now....
xrcr is offline   Reply With Quote
Old 06-11-2018, 10:44 PM   #5
Dead Parrot
Re: Note To Self
Best kind of Oops! No bent metal or smashed and leaking people.
Dead Parrot is offline   Reply With Quote
Old 06-12-2018, 05:08 AM   #6
TKCR
TKCR's Avatar
Re: Note To Self
I believe we have all had a DUH moment, at one time or another. If a Thread ever got started or people posted on this one, to keep it going, I bet there would be some good stories!!
Old 06-12-2018, 06:47 AM   #7
riz
Re: Note To Self
I changed oil on a car once and didn't slide the drain pan out far enough so when I went to lower it down, the tire hit it and flipped up and got oil all over the side of the car......... oil change= 15 minutes..... clean up = over an hour.
RIZ
81 C10 short box
82 K5 Blazer
riz is offline   Reply With Quote
Old 06-12-2018, 07:01 AM   #8
jjzepplin
jjzepplin's Avatar
Re: Note To Self
I worked at an engine shop when I was 19. My boss took a 64 Impala off the jack stands one day when I was at lunch. I came back and he was mad because the rebuilt engine I had installed was knocking so bad he could not let it run for more than a couple revolutions. He should have let me take it off the stands because I had one more under the oil pan that I used with a jack on the tranny pan to help align them for re-connection. So he let the car down on the last stand and buggered up the pan pretty good so it was hitting the crank. The other guy there cranked up my first engine rebuild with no filter on it.Once fixed it still ran really good. I am glad I stopped working there.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 3.73 posi-4-speed Saginaw-307-no budget build.
58 Belair http://67-72chevytrucks.com/vboard/s...d.php?t=756563
99 Trans Am Donor?http://67-72chevytrucks.com/vboard/s...d.php?t=771213
jjzepplin is offline   Reply With Quote
Old 06-12-2018, 07:02 AM   #9
70GMCer
70GMCer's Avatar
Re: Note To Self
YES....keep this thread going.
Makes me feel better knowing that I'm not the only one that has a "Duh" moment...
1963 Chevy Impala
Old 06-12-2018, 09:51 AM   #10
SunSoaked
SunSoaked's Avatar
Re: Note To Self
Spent two days replacing the prop valve in my K20 after an axle swap because the brakes wouldn't release. After all the work and cussing and bloody knuckles, the new one did the same thing! Shortly thereafter, I realized the parking brake was on. The "temporary" tach I mounted on the column was blocking the brake indicator light. I'd like to say this was way back when, but unfortunately it was this past winter.
SunSoaked is online now   Reply With Quote
Old 06-12-2018, 10:05 AM   #11
Gregski
Gregski's Avatar
Re: Note To Self
OMG, that's awesome thank you for sharing and making all of us feel less ahem stupid... I had a similar situation except with wheel chucks under the rear wheels after a recent Z bar clutch adjustment in my driveway, I was like what the heck did just happen how much did I mess this clutch up, now the truck won't move... so I get the feeling
Gregski is offline   Reply With Quote
Old 06-12-2018, 08:57 PM   #12
leddzepp
Moderator
leddzepp's Avatar
Re: Note To Self
The first time I changed oil in my Yukon the oil filter was on so tight I had to destroy it to get it removed. I didn’t notice the gasket remained on the block. I installed the new filter right on top of it (double gasket), when I fired the engine it blew oil through the seem between them and took hours to clean up.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
leddzepp is offline   Reply With Quote
Old 06-12-2018, 10:12 PM   #13
Wizo
Wizo's Avatar
Re: Note To Self
Dear 70GMCer; We are all happy to see that you were disciplined enough to use jack stands.I'm not even going to start lecturing about safety.Heres a pix of one individual who didn't get the memo about jack stands.Keep being safe fellas.
1970 3/4 ton long box GMC
!968 C10 short stepside (Papa's Old Lorry)
2006 2500 HD Silverado Duramax/Alison
Wizo is offline   Reply With Quote
Old 06-12-2018, 11:06 PM   #14
davischevy
davischevy's Avatar
Re: Note To Self
Last week we loaded a big hammer off an excavator into the back of a dump truck. The dump truck bed had water in it. I climbed in the truck, and thought to myself, I can't pull out on the road and dump that water. I raised the bed and dumped the hammer we had just loaded.
other Larry
It's better to keep your mouth shut and appear stupid, than open your mouth and remove all doubt.
davischevy is offline   Reply With Quote
Old 06-12-2018, 11:17 PM   #15
Steeveedee
Steeveedee's Avatar
Re: Note To Self
Many many years ago, one of my sisters asked me to check the brakes on her car. I pulled a front drum, saw that they were OK, and put it back together. Not long after she left, I realized that when I had pulled the drum, the inner wheel bearing and seal had popped out of the hub. I had been working on it in the dark, in the driveway with a drop light. Luckily, she felt the problem and came right back. The drum was rubbing on the backing plate! Time does not erase that embarrassment.
'70 Chevy 3/4T Longhorn CST 400/400/3.54 Custom Camper
"Orange Acres"
Old 06-12-2018, 11:26 PM   #16
Killer Bee
Killer Bee's Avatar
Re: Note To Self
then your crew said 'please go back to your office'
Killer Bee is online now   Reply With Quote
Old 06-14-2018, 07:04 AM   #17
Re: Note To Self
That green truck up on 2 bys is a sketchy set-up. I've seen that picture many times. But looking closer, what is he doing? Is he welding the gas tank or right by it? That's a slick way to hold a truck up and all that, but Golly. That could be dangerous!!
'67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi...'The 67' (project)
'72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok...'The 72'
R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586
special-K is online now   Reply With Quote
Old 06-14-2018, 06:47 PM   #18
FleetsidePaul
R.I.P. E.S.L.L.
FleetsidePaul's Avatar
Re: Note To Self
When we first got our Model A. My friend came over to check it out.
When I wasn't looking he leaned over to my wife and said.
"That' a nice car...Don't let him work on it'
I guess that about sums it up.
1971 Custom 20
1970 Mustang Fastback
2006 Corvette
1980 Jeep CJ5
R.I.P. El Jay
FleetsidePaul is offline   Reply With Quote
Old 06-14-2018, 07:49 PM   #19
jjzepplin
jjzepplin's Avatar
Re: Note To Self
I think timing adjustments on the steering wheel was brilliant!
Old 06-14-2018, 11:07 PM   #20
davischevy
davischevy's Avatar
Re: Note To Self
When I quit running the place about seven years ago, I built a shop and moved all my stuff out back, desk and all.
They pay me to stay away. I go in the front office and complain about how they are doing things a couple times a week to make them feel like they are getting their money's worth.
Yesterday they had a heavy haul over to Eureka Springs that sounded interesting, and I asked if I needed to do it. It got too complicated so I told them to send somebody else and I took my wife on a picnic and media blasted the inner fenders to my K10.
Oh yeah, I didn't share the hammer story with her. She's already convinced I'm incompetent.
other Larry
Thread Tools
Display Modes
Copyright ©2000 - 2019, vBulletin Solutions Inc.
