07-09-2018, 01:38 PM | #1 |
Need springs for 82,C-30!
I have a 82,C-30 dually car hauler that needs spring sets on the rear.
What GM later model springs will fit/work? I'm looking to get some good used ones for it. I haven't measured the length of mine yet,but it has 8 on the lower stack and 4 on the upper stack. I want to buy a newer used set and "build" mine back to what it has or even a little stiffer. Thanks,Mike. |
07-10-2018, 10:25 PM | #2 |
Re: Need springs for 82,C-30!
I've always just bought new, they're not that expensive really. All springs fatigue, why buy used ?
https://www.sdtrucksprings.com/index...8856&x=96&y=13
Tim K. 84 K30 srw Silverado 454 auto 85 C20 350 C6P auto flatbed 94 K1500 lifted shortbed 350 4 bbl NV4500 |
07-10-2018, 11:17 PM | #3 |
New would be around $200.00 per side!
Plus shipping! So,for about $500.00 or so,I won't buy new,when I can buy them in good used condition for less than $200.00 locally with no shipping.What I can afford. Reason I'm asking what will fit. And,the site you offered only shows the lower stack and doesn't show individual leafs.Or,I didn't see them. I need to build them for my hauler,because it hauls a little more than a ton. Thanks for the help. Mike. |
07-10-2018, 11:32 PM | #4 |
OK.
If you could swing them their #22-617HD are 1,150lb per side stronger than regular one ton pickup rears. Just measure width, length, and stack height and go to a "Pick-A- Part" and browse.
07-10-2018, 11:33 PM | #5 |
I replaced all four on my K30 for what the local shop wanted to do the rears only.
07-11-2018, 10:27 AM | #6 | |
But,I have to be careful as I seem to always bring home way more than I originally went after! Mike. |
