Old 10-05-2020, 10:40 AM   #176
joedoh
joedoh's Avatar
Re: 53 3100 - complete rebuild and upgrade . . . .
crazy clean!
Old 11-28-2020, 08:38 AM   #177
big_dan
A little more progress. Finished welding up and fitting the driver side header, so I can put that part behind me. Starting on bed mounts, then I'll pull the cab and bed and finish the exhaust. More later -
Dan
Just playing in my shop, trying to maintain my sanity and maybe finish a project here and there. . . .
My 53 3100 "rebuild" - Soon to be Scott's suspension, LS, low and mean.
https://www.67-72chevytrucks.com/vbo...d.php?t=791886
My 65 Ford project . .
https://www.67-72chevytrucks.com/vbo...d.php?t=792428
big_dan is offline   Reply With Quote
Old 12-21-2020, 04:31 PM   #178
big_dan
Header fab is finished, so snatched the body back off to route the rest of the exhaust and finish welding everything up. Hope to have the frame off the jig soon. Thanks for looking.
More later-
Old 12-21-2020, 04:41 PM   #179
dsraven
you may wanna rethink those headers. looks like you missed the point about getting the hot pipes really close to stuff and making them up so the engine has to be jacked up to get the oil filter off....
kidding. nice job. everything looks really nice.
Old 12-21-2020, 04:59 PM   #180
8man
Wow! Nice work.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 12-21-2020, 06:30 PM   #181
big_dan
Thanks, fellas. About that time of the year to move from "just tinkering around" to wide open on the truck. I get most done in the winter.
More later-
Dan
Old 12-22-2020, 09:10 AM   #182
youngrodder
youngrodder's Avatar
Can't wait to see more. Love your work..
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 12-26-2020, 10:57 AM   #183
big_dan
Again, thanks for the feedback.
Moving forward, about to get the exhaust fabbed up, and I figured I'd better check driveshaft clearance real quick. And . . . . at full squat, if the shocks exploded or fell off, or if i pulled a "Dukes of Hazard" jump, the driveshaft could hit or get really close to a few crossmembers. So, a little surgery and back to it. Best part is there still won't be any floor interference, which i hoped to avoid. Starting a little finish welding also. Thanks for looking.
More later-
Dan
Old 12-28-2020, 09:30 AM   #184
youngrodder
That's why pre-assembly is so important. It helps to uncover the surprises. Confirm your pinon angle. Your probably fine but that bit me thinking I didn't have to cut my floor. Once I got the correct pinon angle, I ended up needing to make a small trans hump.
Marc
Old 12-29-2020, 06:18 PM   #185
big_dan
Marc
Agreed. After I finished tacking everything I checked one last time; pinion 2.5 up, driveshaft level, engine 2.5 down.
Now on to the exhaust . . .
Dan
Old 12-29-2020, 09:24 PM   #186
mongocanfly
mongocanfly's Avatar
Looking good Dan..!!!
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 12-30-2020, 08:39 AM   #187
Mains52
I am copying those rear cab mounts for sure. Great work Dan!
Mains52 is offline   Reply With Quote
Old 01-02-2021, 02:42 PM   #188
big_dan
Thanks for the input!
Been piddling around over the holidays. Worked on the rear bump stops a bit (I made blocks to lower them down to just above the compressed height of the shocks) and then started to play with the exhaust a bit. It'll get tight in a hurry, with 3" exhaust, an H-pipe and cutouts all crammed in to one area, but enjoyable.
Thanks for looking -
Dan
Old 01-03-2021, 07:04 PM   #189
big_dan
Final bit of holiday accomplishments.
More later -
Dan
Old 01-03-2021, 08:26 PM   #190
youngrodder
Looks great Dan!!!
Marc
Old 01-03-2021, 08:35 PM   #191
mongocanfly
man that's some big ol pipes..!!
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 01-04-2021, 06:10 AM   #192
big_dan
I hear you! I would've went with 2-1/2", but keep in mind the final plan is hopefully a 6.0 with a Vortech so I went to 3". Didn't want to have to step up later.
More later -
Dan
Old 03-04-2021, 06:06 AM   #193
big_dan
Just a little progress, but still tinkering along with the exhaust. Trying to cipher exactly where I want my cutouts, mufflers,
etc then we'll finish it up. Once the exhaust is finished, it should be about time to come off the chassis jig and free up some shop room.
Slowly but surely -
Dan
Old 03-04-2021, 10:49 AM   #194
youngrodder
Looks great Dan.. Real-estate becomes hard to come by the farther back on the chassis you go. I had to stop short of the rear deferential. I had originally wanted to go up and over the axle but with the bags, and gas tank location it was not possible.
Keep at it.
Marc
Old 05-30-2021, 07:36 PM   #195
big_dan
Time for a small update - life sure does get busy!
Exhaust is probably 90%, just tips, a little welding and that's it. Decided to turn down in front of the axle for now, and cutouts will dump in front of the tires. Ended up building a crossmember to hold the exhaust and used summit rubber bushings. Goal now is to get it rolling, run fuel and brake lines, then body work.
More later -
Dan
Old 05-31-2021, 09:09 AM   #196
6DoF
6DoF's Avatar
i love the look of the bent tube! and that chassis is going to be super stiff.
6DoF is offline   Reply With Quote
Old 06-01-2021, 08:11 AM   #197
youngrodder
Man that chassis is top notch. I could stare at that for days....Good stuff
Marc
Old 06-01-2021, 08:38 AM   #198
mongocanfly
Really nice tube work Dan..!
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 06-02-2021, 03:33 AM   #199
big_dan
Thanks for the input, fellas. I'm definitely enjoying the process!
After a few days thought, I think I'll go ahead and rough in the alignment and then mock the body/ bed/ fenders up so I can get final measurements for wheels and tires. Diameters are decided, just need to finalize backspace dimensions.
Moving along - thanks for looking
Dan
Old 06-02-2021, 06:51 AM   #200
bennylava
bennylava's Avatar
Question - Was fully boxing the frame necessary? I understand the benefits in terms of rigidity, but would the truck be fine without it? Say you just added a couple new supports. Maybe some beefier cross members. Would that be enough? What are some other reasons to fully box the frame?
bennylava is offline   Reply With Quote
