Old 10-13-2019, 08:57 PM   #1
mick53
serpentine setup
I started playing with my accessories setup today. It seems if I bottom out my harmonic balancer it will be hitting the timing cover. Do I make a spacer for it where the bolt goes? I had to do a little smoothing on the water pump but I think it will work. Alt. and oil pump will need custom mounts made. Probably not the right mandrel for the oil pump and blower pulley but I have a whole box of that stuff I bought at auction, maybe I can barter with them. I need to get the crank figured out to set the engine. The 3/8" spacers are for the crank trigger.
mick53 is offline   Reply With Quote
