09-18-2019, 09:10 PM | #676 |
Re: Our "What are we going to do?" 66 Suburban Build
Struggling a bit with the rear coil conversion kit from CPP...lower brackets are bending down. I pulled them, straightened them, and welded in some gussets...we'll see if this lasts or if they will need to be completely redone.
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread |
09-18-2019, 09:48 PM | #677 |
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread Last edited by RockTonka; 09-18-2019 at 10:16 PM. |
10-04-2019, 03:30 AM | #678 |
We reached out to CBR for some cooling options on both tranny and engine, here's what I've got mounted so far...should help with keeping tranny cooler.
10-05-2019, 02:56 AM | #679 |
We knew we needed a lot more cooling capacity/air flow than the old 27x19 radiator pkg. had provided.
After a bit of back and forth with CBR, we ended up with a 3" thick, 38x19, double-pass radiator that incorporates a unique tube design which dramatically increases the effective tube surface area and a core design that reduces the spacing between tubes from 9mm to 6mm...which means more tubes. All in all, we have a radiator that has over twice the surface area with 2 16" Spal fans pulling 5000 cfm's through it...I don't think overheating is going to be a problem. Our challenge is making it fit...opening up the inner fenders and making a completely new radiator support is the plan.
10-06-2019, 01:23 PM | #680 |
That looks like it will be a tight fit
My 63 GMC Panel Slow Build http://67-72chevytrucks.com/vboard/s...=1#post5457281 63 |
10-07-2019, 12:36 AM | #681 |
Yea, kinda...but we started connecting the dots this weekend and it looks like we'll be alright.
10-09-2019, 06:16 PM | #682 |
Rollin' Old Skool
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
10-10-2019, 01:16 AM | #683 |
I hope so!!
We've got the main framework of the rad support lined out and have started working on fitting in a battery box.
10-13-2019, 03:10 AM | #684 |
We have the battery, rad overflow, and NOS auxiliary fuel system fit back in...pretty tight making everything work. We ended up removing a fair amount of inner fender, but it's all good.
10-13-2019, 03:19 AM | #685 |
More pics...
10-13-2019, 11:32 AM | #686 |
Wow that is a tight fit
10-13-2019, 11:41 PM | #687 |
60-66 Nut
Nice work.......
10-14-2019, 02:17 AM | #688 |
Yep, but it's all in there!
Thanks Capt., we appreciate that! We've had the reworked tranny back from BTE for a couple weeks now. BTE has impressed the s**t out of me with their support and willingness to help with some problems I had with a local builder. If you remember, I sourced a few parts from BTE in spring...aluminum drum, input shaft, intermediate shaft, torque converter, mechanical diode, and a few other little things. I had a local builder assemble the tranny. We cooked the tranny in the first 10 or so miles! I reached out to BTE for direction... I knew there weren't any problems with their parts, but I didn't trust my builder any more. BTE had me send the tranny to them in Mt. Pleasant, MS so they could inspect it. They quickly found a couple builder related problems. BTE completely rebuilt the tranny, tightened up the TC a bit, and had it back to me in less than a week! We reinstalled the tranny tonight...I don't expect any more problems with it.
10-14-2019, 02:33 PM | #689 |
Rollin' Old Skool
Sounds like some great customer service from fellow Mississippian's at BTE as well!
10-21-2019, 01:24 AM | #690 | |
My son didn't like the interior light housing and decided to do something about it. He ground the perimeter down until the center released and replaced it with a piece of light cover from the shop. He's replacing every bulb in the burb with LED's...should be a lot brighter!
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread Last edited by RockTonka; 10-24-2019 at 01:31 AM. |
10-21-2019, 01:31 AM | #691 |
We also disassembled the front end, painted everything, and reassembled...going back together for good...again!
10-22-2019, 09:45 AM | #692 |
Awesome..you going to test it on the dyno
10-24-2019, 12:12 AM | #693 |
No, not on a chassis dyno. It's been tuned on the engine dyno...that was important to get it dialed in. I can't justify the $$ for time on a chassis dyno.
10-24-2019, 01:28 AM | #694 |
Continuing with the conversion to all LED...much brighter!
10-28-2019, 01:29 AM | #695 |
We finished up most of the wiring (lights, new fans, tranny temp sensor, etc), topped off all the fluids, and put a few miles on it this afternoon.
We kept it conservative...only about 20 miles, but we did hammer on it a few times. Everything kept cool...maybe too cool. The burb ran great though, gonna try to just kick back and enjoy it for a bit...although there are a few more things I want to do to it.
10-28-2019, 01:47 AM | #696 |
10-28-2019, 09:53 AM | #697 |
Dadgum, definitely my favorite suburban
Are y'all still running the Camaro rear sway bar?
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
10-28-2019, 11:03 PM | #698 | |
Thanks CW! We pulled the rear sway bar off...the mounts on top of the axle were hitting the frame as we played around with spring rates on the coil overs. We will run a bit with just the coil overs to see if they can compensate much for body roll...we have adjusted the rebound/compression a bit with positive results though.
10-29-2019, 12:46 AM | #699 | |
I just went back to where y'all installed it (page 12 for anyone else wondering) to see how y'all had mounted it. I want to add a bar to my truck as well, so I've been gathering up ideas. Still have stock stuff under mine, so no worries about hitting anything yet. Sounds like the coil overs are the way to go, but for now, stock is just fine
10-29-2019, 01:09 AM | #700 | |
If you were closer, I'd make you a deal on my old one...shipping probably isn't worth it.
