02-27-2011, 03:04 PM | #1 |
64 Fuse Block
Turns out I need a new alternator. So after that is done I need to get the fuse block mended as well. From the picture it looks like I am missing a fuse clip on the bottom. Is there anywhere to get a replacement? Second problem. Nothing is connected!??? Does anyone have a picture of of their block? I am going to have to crawl under there and start fishing for wires. The only other wire i found was a black wire with alligator clips on both sides? not sure where it came from. All the wiring looks original and in tact. I am guessing the previous owner pulled all the wires from the fuse block shortly after the alternator went out.
02-27-2011, 03:39 PM | #2 |
Re: 64 Fuse Block
I think you are ok-as-is, as I see it and your fuse box looks just like '65's.
The last "fuse" is for the tail lights / dome light. Under that is a plug in connection for a spot light, you don't have one, therefore there is nothing there. Again, as I understand it, that's the deal. I hope that helps... Last edited by lakeroadster; 02-28-2011 at 09:23 AM. |
02-27-2011, 10:15 PM | #3 | |
Re: 64 Fuse Block
Posted via Mobile Device |
02-28-2011, 09:10 AM | #4 |
Re: 64 Fuse Block
Here is a photo of my 1965 C10 fuse box for comparison.
02-28-2011, 10:21 AM | #5 |
Re: 64 Fuse Block
02-28-2011, 08:57 PM | #6 |
Re: 64 Fuse Block
Slightly off topic, but if a truck didn't come with a radio from the factory would the underdash harness still have the plug for one? or can you buy them seperately?
02-16-2012, 11:15 PM | #7 |
Re: 64 Fuse Block
is this the same box that goes for a 1963
03-17-2012, 08:47 AM | #8 |
Re: 64 Fuse Block
Does anyone sell a new fuse block like these? My terminals have gotten rusty and sometimes don't make a good contact.
Friends don't let friends drive Fords |
04-14-2018, 08:02 AM | #9 |
Re: 64 Fuse Block
So I have a question as well. I have a wire coming out of the B. U. LPS. This is a brown wire. Where does it go? My best guess is backup lamps but I don't have any on the truck ??
63 C10 |
04-14-2018, 08:03 AM | #10 |
Re: 64 Fuse Block
I have a 63 and mine is identical
63 C10 |
04-14-2018, 12:23 PM | #11 | |
Moderator
Re: 64 Fuse Block
http://www.wiringharness.com/ Their catalog - http://www.wiringharness.com/PDFS/TR...hevy_Truck.pdf Good luck.
04-14-2018, 04:17 PM | #12 |
Re: 64 Fuse Block
I have everything working except instrument panel lights. I have no power on either side of the fuse. I turned the fuse panel around and don't see anything broken or disconnected. What am I missing?
04-14-2018, 04:56 PM | #13 | |
Re: 64 Fuse Block
Since you don't have power on either side of the PANEL LTS fuse, the problem is most likely in the headlight switch rheostat. They have a tendency to get dirty / corroded and no longer make good electrical contact. Sometimes simply rotating the knob back & forth a few times will scrape off some light corrosion and get them working again. You could also try spraying some electrical contact cleaner on the rheostat portion of the switch (it's the part that looks like a coiled wire near the knob end of the switch). But if that fails, you'll probably have to replace the switch. Note that if the problem were farther "upstream" in the circuit it would likely affect the brake lights, tail lights, and dome light too. |
04-14-2018, 06:40 PM | #14 |
Moderator
Re: 64 Fuse Block
Rheostat.
04-14-2018, 10:49 PM | #15 |
Re: 64 Fuse Block
Thank you for the help.. I will try to check it tomorrow. The truck has been off the road since the fall of 08. I am so ready to drive it again.
05-01-2018, 08:12 PM | #16 |
Re: 64 Fuse Block
05-02-2018, 04:50 AM | #17 |
Scrapper 1
Re: 64 Fuse Block
I feel if some one has hacked up harness that bad.Me i spend the 399.00 for a brand new fuse box and under dash harness.To me I did mine 12 years ago spent 599.00 for everything.And not one problem never left me on the side of the road
10-12-2019, 11:36 AM | #18 |
Re: 64 Fuse Block
B.U. Laps
Back Up Lamps |
