06-03-2017, 02:43 PM | #1 |
Lifter replacement
I recently replaced both lifters on the #5 cylinder of a sbc 350. My question is that I did not put any lube on the bottom of the lifters I did soak them in oil before I dropped them in. I replaced the old intake manifold gaskets and installed the intake manifold and torqued it down. Is it enough for me to prime the oil pump before starting or should I pull the intake back off and lube the the lifters?
Thank you, Ian
- Ian 1966 C10 Longbed 350/350 |
06-03-2017, 04:12 PM | #2 |
Re: Lifter replacement
I'm betting if you prime it, you should be ok. It might be worth taking the valve cover off, putting a little assembly on both ends of the pushrods for the lifters you replaced.
06-03-2017, 04:36 PM | #3 |
Ok, I also replaced the push rods so just take the rods out and apply moly to each end. And after that should I just follow cam break in procedures?
06-03-2017, 07:05 PM | #4 |
Sure you can prime it, lube it and do another break in but the odds are against you.
Cam might go flat anyway. But you gotta do everything you can to increase your odds! Why the 2 lifter change? |
06-03-2017, 09:02 PM | #5 |
When cam lobes are machined there is a 4 degree angle built into them so it makes contact with the outer area of the lifter bottom to cause it to spin and this helps with preventing accelerated wear on the lifter, pushrod, and rocker arm. If you take the old lifters and butt the bottoms up against each other and try to see light through. If the lifter bases are cupped at all you will see light shine through in the center of the bases.
Sbc's have had cam/lifter wear issues at times back in the 60's and newer, and this was when zddp was in a high percentage in almost all oils. Gm's E.O.S. (engine oil supplement) if they still sell it was the standard thick goo to put on lobes, lifter bases, and add to the oil for breakin purposes. Remember that cams get there lube from the oil being thrown of the connecting rods so keep the rpm's off idle, especially during the first 10 minutes. Good luck. |
06-03-2017, 09:40 PM | #6 |
Well I have very little experience with engines. I had a family member come check out my engine after I had found I had a broken rocker arm and broken push rod both on the same cylinder. So the side the rocker arm broke the push rod did not. The side the push rod broke the rocker arm held up. So after looking at my engine he thinks the lifters were the issue that he could not get them to compress at all. He also checked inside the valve and watched and felt the cam for any wear signs.So I replaced the arms push rods and lifters. I'm hoping this is the only problem if not it looks like I will be replacing the cam and all.
06-03-2017, 09:41 PM | #7 | |
06-03-2017, 09:53 PM | #8 | |
But if the cam wipes a lobe you'll be doing more than replacing just the cam. It'll be a complete teardown and refresh. |
06-03-2017, 10:03 PM | #9 | |
Ian
06-03-2017, 10:06 PM | #10 |
What method did you use to set the valves on that cylinder?
06-03-2017, 11:08 PM | #11 |
I did not set the valves on it before this happened. I was planning to set them with it running. I have also read methods of doing it with the engine off. Do you have any suggestions?
06-03-2017, 11:21 PM | #12 |
Did you change just those two rockers and pushrods on #5 or did you change all the rockers and pushrods?
Your answer will determine the advice. |
06-03-2017, 11:40 PM | #13 |
Just the rockers push rods and lifters on the #5.
06-03-2017, 11:57 PM | #14 |
Adjust them cold like in the first post in this link.
https://www.jalopyjournal.com/forum/...valves.168345/ You can adjust them hot later if you like. There's also youtube vids if you search a bit. |
06-04-2017, 12:01 AM | #15 |
60-66 Nut
My advise is to pull the intake and remove the lifters and lube everything correctly. Why take a chance that could cost you a complete engine rebuild?
06-04-2017, 12:06 AM | #16 | |
06-04-2017, 12:08 AM | #17 |
True, I put on a new fel pro intake manifold gasket and already torqued it down. Would the gasket still be ok to use or would I need to replace it again?
06-04-2017, 02:07 AM | #18 | |
Id really take the advice of pulling the manifold and getting some good lube on the bottom of the lifters. Cheap insurance that will better your odds. If it takes those lobes out, you're looking at pulling the manifold again anyway.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
06-04-2017, 11:35 PM | #19 |
60-66 Nut
You will need a new intake gasket set.
06-05-2017, 12:25 AM | #20 |
Isn't it better to install a whole new cam kit than just replace 2 lifters? If the o.p is running a greater risk of wiping those lobes out and ruining the motor, shouldn't he just get something like a Summit house brand cam kit and timing chain?
06-05-2017, 06:03 AM | #21 |
If the cam is fine and you just have 2 malfunctioning lifters, I see no problem with just replacing the 2 lifters. It saves tearing the engine down further and buying all new parts on a higher mileage engine. I wish the lifters were lubed better though. I would agree with others and lube the lifters better and put in new intake gaskets. It's just another hour of wrenching and maybe $20 for gaskets.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
06-05-2017, 07:28 AM | #22 |
Pictures of the bottoms of the old lifters will help give an indication of the shape of the cam. If they are nice and flat there may me a chance the new lifters will survive. If they are dished a good bit then the cam could already be worn out. Bump the engine over once you have them adjusted cold to see if they are both moving about the same as the rest of the engine. If one in not moving much that lobe is wiped on the cam. To help with your learning curve, a lifter full of oil is not that easy to push down by hand. When you learn to do them running you will see how long it takes one to bleed down when you are doing your adjustments. It can take several seconds to bleed down even with the pressure of the valve spring.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
06-05-2017, 04:38 PM | #23 | |
Thank you!
06-05-2017, 04:45 PM | #24 | |
06-05-2017, 04:51 PM | #25 |
Here's a few pictures of the old lifters
