06-04-2017, 11:02 AM | #1 |
cant quick disconnect heater hose
meant to say cant FIND...
1991 chevy silverado 350 on the back passenger side of the motor there is a quick disconnect fitting that looks like this im having no issues finding that fitting, but cant find the short metal/rubber hose that goes into that then into the heatercore. just wondering if anyone ran into this before? it would be nice if they sold that fitting with just a nipple on the end to hose clamp directly to it. bought the engine out of the truck so the hose is cut right at the crimp so cant even put a double barb fitting in there |
06-04-2017, 11:28 AM | #2 |
Re: cant quick disconnect heater hose
The fitting itself has 1/2" threads on it. Go to a hardware store and get a 1/2" fitting with a hose barb on one end and instead of buying the correct hose that has the metal in it to connect to the quick disconnect just get regular heater hose and use that instead.
06-04-2017, 04:15 PM | #3 |
I have been thinking about putting this on, Mine had failed a few times. http://www.getfast1.com/PSS-1004-P-S...ng_p_2731.html
06-06-2017, 01:09 PM | #4 | |
the broken thing i was looking for and the piece i took out of the other engine, looks like someone else did that idea as its two adapters in one this will probably work out better as this engine is going into a 50s truck and doubtful it would have worked well anyways. sorry for wasting time, found that fitting yesterday while messing around in the garage |
