11-17-2017, 02:35 PM | #201 | |
Re: 1949 Chevy with S10 swap. Beginner build with ambition!
Current Build Thread 1930 Ford Model A Modern Twist: Ford Model A Rat Rod With a Modern Twist Build Thread Phase 1 "The Swap": 1949 3100 with S10 swap. Beginner build with ambition! Build Thread Phase 2 "The Drop": Beginner Build with Ambition gets Air Ride |
11-17-2017, 04:35 PM | #202 |
every time i fill one up from slap empty it needs a temp spike to get rid of any air pockets. if you notice bubbles coming from the tube on the rad, you might have air in the system.
the way to get rid of air in a cooling system when you have an expansion tank and a two way rad cap is to put some 50/50 in the expansion tank, warm the engine to operating temp, then shut it off and wait. the air will be forced out while running and then the radiator will reverse pressure as it cools back down (not running) and will draw coolant from the tank. if you dont have a tank hooked up, it will just draw air back in and you will need to start all over. otherwise, make sure the thermostat is opening. feel the upper and lower hoses, if one is hot and the other is cold and the engine is warmed up, the thermostat may not be opening.
11-18-2017, 01:56 PM | #203 | |
It also helped to put an air cleaner on the carb for tuning. I was trying to do it without one. Radiator had a burp at 190F that dropped the temp straight back to 150F and has been great ever since. I did setup a siphon system for now just in case. May make that permanent just cause bourbon makes everything run better. The missing ingredients! Putting sheet metal on the front so I can give her a first drive. I did learn that a transmission takes way more than 3qt to fill. I think I am at 9qt now and probably still need some more once I've run it through the gears.
11-19-2017, 11:28 PM | #204 |
I like the idea of the burping on the rad. I always just left the cap off and let them burp, usually works. but..... my last build when I hooked the heater up, I had the craziest air pocket I could get gone for the life of me. The day I sold the truck I was able to get it out! as for timing, def invest in a light. but a good rule of thumb is if it starts up good and shuts down good when hot, you are in the ball park. as for trans, I think they take 11or 12 qt. be an easy find on the net.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
11-20-2017, 11:09 AM | #205 |
I have cats. any coolant spill is an emergency hazmat situation with the garden hose.
11-20-2017, 01:45 PM | #206 |
haaahah yeah I got dogs, so I'm always careful with coolant. I've been lucky enough to never have it spill out, I usually keep a funnel in the rad with a rag around it Just in case.
11-20-2017, 03:50 PM | #207 | |
Not saying it happened, just asking for a friend. Are you saying that is bad? Yeah I stuck a gallon in there after the 4 qts and got up to about 9.5qt. Looks pretty close but I haven't driven it yet to slosh everything around. I did get the car to start and idle nicely, once warm she shuts off fine. I also don't have the smog coming out of the exhaust I was having before from unburned fuel in the exhaust. In gear (Reverse or forward) the engine bogs down but doesn't cut out when I'm on the brakes. I feel confident I'm in good shape enough to get to a store and have someone set the timing correctly. Once I've done it, I can't imagine having to go back and do it again
11-21-2017, 12:17 PM | #208 | |
11-21-2017, 12:23 PM | #209 |
transmission tunnel finally fitted. Stole someone elses idea for building a frame around the outside so its removable. Took about 30 cuts to get the S10 tunnel fit perfectly haha. As you can see, I might have screwed up the hole for the stick a little. Nothing a bit of filler metal can't fix. I'm not worried about how pretty it is since this will be covered in dynamat and carpet someday.
I used the old floor section to trace a new one onto some 16GA sheet I used an 8" piece of string to draw a radius for the firewall side and made it 2" thick. Matched the two pieces up and tacked them in Took the S10 trans tunnel I had cut out previously and slowly worked it into the new location. This was made easier by the fact that the first step gave me a template I could take out of the truck and put on the ground for measuring, cutting, measuring, grinding, cutting again and then welding it up.
11-21-2017, 01:03 PM | #210 |
Nice work! Looks similar to my tranny cover. I went the opposite way. Original floor plate and fabbed "upper" piece.
You are making great progress. If you're going to spend the money on a timing light, do yourself a favor and get one that has the advance dial. Then all you have to worry about is your marks matching up at TDC.
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
11-21-2017, 02:51 PM | #211 |
looks good! I use liquid nails fuze it as a seam sealer, it makes the joint stronger and seals it!
11-22-2017, 06:06 PM | #212 |
man oh man oh man! I drove her!
First drive out of the garage and down the street. No hesitations. Shifted great. Way more torque and power than I expected. JoeDoh, I have officially completed your suggestion of only doing things that get it driving. Now onto the rest Beauty is in the eye of the beholder, although I think my fellow car people on this board can appreciate the potential ahead on this build. woohooo!
11-22-2017, 08:19 PM | #213 |
way to go! looks good!
11-23-2017, 02:00 PM | #215 |
congrats, that first fire up or first test drive is the best feeling. really puts some wind in the sails to finish. But..... the punch list big or small still seem to drag on even when the truck starts, runs, stops!!!
11-23-2017, 03:44 PM | #216 |
Yeah once the excitement subsided I started a new list of "what do I need to register this thing for the road." Already have an order in for tail lights haha
11-24-2017, 06:42 PM | #217 |
Nice work...The first drive is always the best..
Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
11-24-2017, 06:59 PM | #218 |
Congratulations. The first drive really helps to get the enthusiasm back.
11-25-2017, 10:14 AM | #219 | ||
Sorry about this late response, another old timer trick is to drill 1/8 hole in the flange of the thermostat. This helps circulate coolant through out the system before the thermostat opens. Less air pockets.
Desert |
11-25-2017, 09:23 PM | #220 |
This works. I believe LS thermostats already have the hole, so those engineers learned something finally
12-04-2017, 12:45 PM | #221 |
Well that was a nice surprise. Running boards mounted this weekend. After carefully measuring, I realized the running boards are perfectly in line with the bottom of the S10 frame. So a single length of 1x2 steel did the trick for each of the mount locations.
Also an excuse for another drive haha..had to turn the truck around, so I took the scenic route through the neighborhood. Grill and bumper are on too. I'm moving so quick I forget to post pictures for you guys. I'm not happy with my bumper mount, but I gave it the scientific "jump up and down on it" test. It will have to do for now.
12-04-2017, 02:24 PM | #222 |
How far is your bumper off the floor.
12-04-2017, 05:01 PM | #223 |
Congratulations! I really like the stance.
If you don't mine, PM me as I have some questions about frame height and cab height. |
12-06-2017, 10:27 AM | #224 |
8.5" for height on this one. I think the bumper will end up 1-2" higher when I change wheels for the 18" rims I have. Currently sitting on the original S10 tires that are 24.5" in diameter.
12-06-2017, 10:28 AM | #225 | |
This diagram I drew might help...
