Old 02-20-2012, 12:06 PM   #1
bloodybigblock
bloodybigblock's Avatar
best bang4buck sbc crate engine??
Opinions? I have a 2wd k5 with a 305/th350 and 2.73 gears. I really like having higher gears for my interstate cruising but Im in need of a new motor since mine is 34 years old. I plan on using this as a weekend driver and to tow across state maybe once a month. Any suggestions will help. I was thinking of a blueprint 355 or gm350 that has 260hp. Thanks
bloodybigblock is offline   Reply With Quote
Old 02-20-2012, 05:46 PM   #2
Wrenchbender Ret
Re: best bang4buck sbc crate engine??
The 260 HP Goodwrench is a hard package to beat. I Have sold hundreds of them when I had A shop & now I use them on all my projecs. I'm close to getting one for my 56 & taking out the 6 cyl.
Wrenchbender Ret is offline   Reply With Quote
Old 02-20-2012, 07:52 PM   #3
kody
jegs has free shiping right how, they have have 260 hp for 1499.99
kody is offline   Reply With Quote
Old 02-20-2012, 10:00 PM   #4
mx574
i got a gm goodwrench 260hp for my 1969 truck in 2002-truck was a daily driver. in 2007 got another truck. parked the 1969 and built it again this time with a high performance motor-not a daily driver anymore- motor is a blueprint. i had little issues with blueprint when i got it but since i started driving it it rocks. has a 30 month 50k mile warranty. and i believe their prices are best bang for your buck. would recommend blueprint
mx574 is offline   Reply With Quote
Old 02-20-2012, 10:23 PM   #5
bloodybigblock
You think the 260hp crate will be good for towing my other truck across state? I was looking at the edelbrock packaged crate from jegs.
Old 02-20-2012, 10:28 PM   #6
bloodybigblock
Goodwrench crates come with warranties? It'd be hard to beat a 3yr 50k warranty.
Old 02-20-2012, 11:55 PM   #7
frednoah
Pickup Man
I would give a look at GM part #12530282. Vortec heads and a roller cam for around 2 grand. Swap in a little bigger cam and I think you'd have a lot more fun with this than the 260 hp motor everyone swears by.
http://www.summitracing.com/parts/NAL-12530282/
frednoah is offline   Reply With Quote
Old 02-21-2012, 02:01 AM   #8
C-10 simplex
Tell me more. Also, i think the 4-bolt version is about $100 more---#12530283?
C-10 simplex is offline   Reply With Quote
Old 02-21-2012, 05:18 AM   #9
blackedoutharley
You will also need to return a suitable core for either of these engines. And the freight charges on sending in the core, if you have one, are your responsibility.
The 260 hp or 290hp engines are still the best deal out there.
blackedoutharley is offline   Reply With Quote
Old 02-21-2012, 10:00 AM   #10
cdowns
cdowns's Avatar
a great way to void the warrenty right out of the box
Old 02-21-2012, 11:49 AM   #11
bloodybigblock
Agreed. im a fan of a warranty. I'm sure either Goodwrench engine I capable of pulling another truck with my k5. I do know my 305 is a turd. I think I'm set on the edelbrock packaged 260hp crate.
Old 02-21-2012, 03:37 PM   #12
Warrens69GMC
Warrens69GMC's Avatar
Originally Posted by blackedoutharley View Post
You will also need to return a suitable core ...
Take the 305 to scrap and get $50 for it
(Steel @200 a ton, a 500lb motor will get $50)
1969 307, t350
1950 Chevy Wagon
Old 02-21-2012, 03:48 PM   #13
dave666693
dave666693's Avatar
Go to your local GM dealer parts guy. They will typically match prices and saves you the freight.
67 C20/
68 C10 stepside/inline 250--current project
71 GMC 4x4
70 Blazer project-Zombie assault vehicle
67 4x4 Burb
dave666693 is offline   Reply With Quote
Old 02-21-2012, 06:21 PM   #14
C-10 simplex
That's funny, Jegs makes no mention of core charge and it's cheaper and free ship. Pace adds in a $100 core charge.
These are new engines, so i don't get where the core charge comes from...........?
Old 02-21-2012, 06:36 PM   #15
C-10 simplex
Even funnier----#12530284, the 305 version of the two bolt DOES NOT have a core charge at summit or pace.
What's going on?
Old 02-21-2012, 07:15 PM   #16
frednoah
Pickup Man
If the truck is a daily driver, and his sole means of transport, I can see your point. If it is a toy that is going to be driven a few thousand miles per year, the warranty will be up before he hits 5k miles anyway. My truck is a toy, and I don't mind paying to play if I break something.
The core charge is $100 if you don't send it back. Hardly a deal breaker if you're spending $2000+ on a motor.
The 260 hp engine is a good, cheap engine for a truck that gets a lot of miles put on it.
The 290 hp version is the exact same motor with you paying $400 more for GM to stick a different cam in it. Hardly bang for the buck in my opinion.
If you were to buy the 260 hp engine and outfit it with Vortec heads, you're still going to have a flat tappet cam, and more $$$ invested because of the cost of the heads themselves and the self aligning rockers.
If you are worried about warranty, you can leave the stock cam in the motor I listed. The lift and duration #'s are pretty much in the middle of the road between the 260hp and 290hp cams.
The 260hp package is a good motor and should serve you well for a long time. I bought one for a 56 Chevy I had a few years back.
If I had to do it over I'd have went with the engine I linked above. Better heads and the piece of mind that the roller cam provides are definitely worth the extra $$$. Not having to worry about wiping a cam lobe during break in is more than worth a few hundred bucks. The main negatives to buying this motor are spending around $60 extra on your intake, and running an electric fuel pump.
Old 02-22-2012, 09:39 AM   #17
Warrens69GMC
A new flexplate too.
1969 307, t350
1950 Chevy Wagon
Old 02-22-2012, 10:41 AM   #18
C-10 simplex
Why core charge on a new engine?
Old 02-22-2012, 12:32 PM   #19
Lee H
Lee H's Avatar
I have seem local GM dealers meet on-line pricing for crate engines. No shipping cost.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 02-22-2012, 03:09 PM   #20
cdowns
cdowns's Avatar
plus local dealers have more incentive to help you if you buy from them and then in the rare instance you need help with warrenty service
Old 02-22-2012, 04:00 PM   #21
storm9c1
*** That's interesting ***
storm9c1's Avatar
Two possibilities, but both are guesses on my part. 1) that engine was made with a reman block, which most are nowadays. 2) environmental laws govern the selling of reman parts; case in point, the wording on the Advance Auto Parts website: "Core Charges are often mandated by state legislature, and, as such, the actual core charge and taxes on the charge may vary depending on the state in which you buy your part."
Tom
Chevy by day...
1969 Chevy C30 Rollback Tow Truck -- 383 stroker, 4L80E
2011 Chevy Caprice PPV 9C3 6.0L (6K miles)
1995 Chevy Caprice 9C1 (177K miles)
1994 Chevy Caprice 9C1 #3 (99K miles)
1995 Chevy Caprice Wagon #2 (60K miles)
1995 Chevy Impala SS (20K miles)
Mopar by night...
1969 Dodge Charger
1972 Chrysler Newport 2dr Hardtop (27K miles)
Plus others...
storm9c1 is offline   Reply With Quote
Old 10-07-2017, 01:08 PM   #22
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
What route did you end up going with?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 Service truck build:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 10-07-2017, 07:24 PM   #23
garyd1961
Most cars on the road today have an electric fuel pump and summit sells a nice aluminum intake for around $150. As for the flexplate Summit has a SFI rated one for around $80 that works great, I have used two of them one on a hot 383 another on the 12530283 GM vortec crate engine.
The 12530283 crate engine is an awesome motor for these trucks. With a Holley 4 barrel and good pipes it has a lot of power. DO NOT get the 290 hp motor, it has no low end torque.
I'm pretty sure the 12530283 is a brand new block. Jegs advertises it as brand new and there is no vehicle ID stamp on the block. Also it's a standard bore not .30 over.
Say what you like but the vortec 350 is the last version and most improved version of the old 350 motor. I have yet heard anyone to say they wish they had went with a 260 hp motor instead of the vortec.
garyd1961 is offline   Reply With Quote
Copyright ©2000 - 2018, vBulletin Solutions Inc.
