Old 09-28-2017, 06:34 PM   #1
CampaS75
TH400 rebuild ?
I have a '75 GMC motorhome that had the transmission fail badly so removed it. Bought a rebuild th400 that came from an '87 Chev truck not realizing it was 27 spline and my original is 32 spline. I didn't take the rebuilder's tape off until I removed old from motorhome.
So, is it possible to swap old 32 shaft to the rebuild th400 ?
CampaS75 is offline   Reply With Quote
Old 09-28-2017, 08:09 PM   #2
mongocanfly
Re: TH400 rebuild ?
clinebarger can answer that but I'd assume the trans would have to be disassembled completely to do so...if its possible...wouldn't it be easier to just change the yoke?
mongocanfly is online now   Reply With Quote
Old 09-28-2017, 08:20 PM   #3
CampaS75
Re: TH400 rebuild ?
It's the tougher 32 spline shaft I'm trying to keep because it's pushing 10000 GVW and don't want to risk it snapping on a smaller 27 spline. I realize both transmissions would have to be disassembled to do so but I don't know if they're simply swappable once all apart.
Old 09-28-2017, 10:51 PM   #4
Warrens69GMC
Warrens69GMC's Avatar
Re: TH400 rebuild ?
You want to also see if it needs the lockup wired in to work.
1969 307, t350
1950 Chevy Wagon
Old 09-28-2017, 11:15 PM   #5
Captainfab
60-66 Nut
Re: TH400 rebuild ?
The TH400 trans from a large motorhome such as that should actually be a TH475. Does it have the drum parking brake mounted to the back of the trans?
Old 09-29-2017, 12:19 PM   #6
DieselSJ
Re: TH400 rebuild ?
TH400 lockup?
I wasn't aware of such a thing.
87 R30 CC Dually, 454, TH400
87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4
DieselSJ is offline   Reply With Quote
Old 09-29-2017, 02:11 PM   #7
kwmech
Re: TH400 rebuild ?
27 spline 400 in an 87? not likely. Sure it's a 400 and not a 700? Anyways, both will have to come completely apart to swap outputs. The output is held into the rear planetary drum with a snap ring.
Old 09-29-2017, 02:12 PM   #8
kwmech
Re: TH400 rebuild ?
Originally Posted by DieselSJ View Post
TH400 lockup?
There isn't for a 400. if it was it's called a 4L80
Old 09-29-2017, 06:42 PM   #9
clinebarger
Re: TH400 rebuild ?
Sounds like a TH375 out of a 1/2 ton truck.....
There will be fewer frictions compared to a TH400/475.
You will need to compare Boost Valve sizes.
The Governor will be wrong for the application.
The 27 spline output shaft just might hold up.....But the drive shaft & slip yoke changes probably negate any savings here.
The Unit has to be tore all the way down to change the output, At the same time you need to add a friction to each clutch pack using the Forward & Direct Pistons along with the Intermediate Pressure Plate out of your old TH475.
There are some more upgrades that I would recommend if you decide to open it up.
clinebarger is offline   Reply With Quote
Old 09-29-2017, 06:57 PM   #10
CampaS75
Re: TH400 rebuild ?
Well I just got back from looking at several transmissions and none match mine without adjusting yoke n driveshaft.
So I think now i might use the rebuild and get yoke n driveshaft altered.
Didn't know it'd be this tough to find a match !
Old 10-09-2017, 08:27 AM   #11
YoungPup1977
Re: TH400 rebuild ?
The best thing to do is rebuild the trans that came out of the MH.... replacing the original with a lesser TH375 could present problems down the road. 10K GVW on a TH375, how long you think it will last ? If you like R&Ring the transmission on the floor on your MH use the TH375 but rebuilding the original transmission in my opinion would be a better way to go.... sell the TH375, and use the cash to rebuild the original.
What should the lesson be learned here ? Be aware of what you are buying before you toss the cash down....its not a daily driver so time is not an issue...rebuild the original to make sure transmission is designed for the application....there are always upgrades for every application but never replace the original with a lesser application....GOOD LUCK !!!!!!
YoungPup1977 is offline   Reply With Quote
Old 11-20-2017, 02:27 PM   #12
CampaS75
Re: TH400 rebuild ?
Update ...
I ended up going with new rebuild that a fellow Chev mechanic had used in a '69 Camaro that was featured on Barret Jackson auction with basically 0 kms on it. $400 !!!
It works great (TH400).
But now I have another problem...
Brakes. Hydraboost(no vacuum assist).
Here's the thing:
I added hydraulic boost oil in summer. I didn't realize it thickened up so much in winter. Scooped out top oil out of master cylinder. Then sucked up thinner brake fluid with a Sunlight bottle. Put fresh fluid in and got a buddy to pump brakes while I bled them. Still no brakes n light still on.
Any advice ? Air compressor each line ?
Old 11-20-2017, 07:04 PM   #13
kwmech
Re: TH400 rebuild ?
2 separate systems. Brake fluid under the cap only, and Power steering fluid in the power steering pump reservoir. Hope you did not cross contaminate
Old 11-20-2017, 07:20 PM   #14
CampaS75
Re: TH400 rebuild ?
Transmission fluid in both.
Until I get pressure back then I was going to bleed out and put brake fluid. This is the second used parts I've installed. 1st one lasted about a year then failed all of a sudden(no wrong fluids).
Then bought a 2nd used set (both master cylinder and boost).
It worked up until 2 weeks ago. Bled fine and worked
So I dunno. I'll probably take back off and flush with solvent suck as gasoline.
Old 11-23-2017, 12:35 PM   #15
truckdude239
truckdude239's Avatar
Re: TH400 rebuild ?
If you us2d transmission fuild in the master cylinder your brake system is done you will need a new master cyli der capliers rubber hoses and rear wheel cylinder trans fulid will eat the rubber out of a brake system you might has well start from scratch with the brake hydricals if i has trans fulid in the side that suppose to have brake fuild the system is done
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 101kmiles
2002 Honda Accord 4 door With 275k(sisters car)
1998 Honda Accord 4 door with 318k(brothers car)
Old 11-23-2017, 12:36 PM   #16
truckdude239
Re: TH400 rebuild ?
Do not use gas flush metal hard lines with brake clean and blow out with air
David fuller
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
