Old 10-07-2017, 08:36 PM   #1
Short 3/4
Active Member
K20 brake part question
I'm trying to correct P.O. butchering of the front drum brakes on a stock 65 K20. The adjuster hardware is nowhere near correct, but I can't seem to find new or used replacements. Even old worn parts would help as could use to match correct parts. Any help or parts numbers/sources would be great.
Thanks, Tom
65 short stepside K10
292-SM420-T221
8 lug closed D44 front
NoSpin HO72 rear 4.10
Short 3/4 is offline   Reply With Quote
Old 10-08-2017, 11:30 AM   #2
Bigdav160
Bigdav160's Avatar
Re: K20 brake part question
Do you know what axle you have? IIRC, GM didn't build 4WD's in-house during that time period.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 10-08-2017, 12:56 PM   #3
61K10
61K10's Avatar
Do you have a pic? post up a pic if so. GM started building k trucks in 1960 1/2t and 3/4t. one ton and up was still NAPCO
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 10-08-2017, 02:15 PM   #4
Short 3/4
Active Member
It's a stock factory 65 K10 1/2 ton 4x4 with a stock factory 65 K20 3/4 ton front end that I bolted up to it. Brakes are the stock 3/4 ton 12x2 inch. Parts for 1/2 tons are easy, but nobody has much for the 3/4 tons. I have tried all the usual local and mail order sources with no luck
Thanks for any help, Tom
292-SM420-T221
Old 10-08-2017, 04:35 PM   #5
61K10
61K10's Avatar
So what you're saying they are different than 1/2 t? They changed the front brakes in 63 or 64 in the 1/2 ton. don't know about 3/4t. A pic of what you have would help figuring wat you have.
1961 chevy K10
Old 10-08-2017, 08:42 PM   #6
Short 3/4
Active Member
I'm sorry I was not very clear. I looked back at my original post and saw I should have said the SELF adjuster hardware. This would have been newly introduced in 64 and should be the same for 64 65 66, but don't know if parts the same for later years of drum setups. I have the correct backplate/shoes/drums/cyls/adjusters/etc. All I need is the self adjuster leavers and springs. I have complete 65 1/2 ton set-up but is not same as 3/4 ton. Can't really post a picture as all I have is a bunch of parts I can't bolt together until I have everything. Was hopping somebody with a K20 could post a picture.
Sorry I messed up original question. Anybody out there with a 4-5-6 K20 still have original brakes?
Thanks, Tom
292-SM420-T221
Old 10-12-2017, 10:17 AM   #7
Short 3/4
Active Member
Still looking-Anybody?
292-SM420-T221
Old 10-15-2017, 03:25 PM   #8
gmc 2500 4x4
i went thru a long process with my 69 gmc. it has 12'' brakes also. 3/4ton. some parts may be the same
gmc 2500 4x4 is offline   Reply With Quote
Old 10-15-2017, 04:29 PM   #9
Short 3/4
Active Member
I'm thinking that they are pretty much or exactly the same. Where did you get the parts? Pictures or part #'s would be a great help if possible.
Thanks, Tom
292-SM420-T221
Old 10-15-2017, 06:17 PM   #10
gmc 2500 4x4
heres what my 69 book shows,
Old 10-15-2017, 06:42 PM   #11
gmc 2500 4x4
https://www.carid.com/1965-chevy-ck-...181835155.html
Old 10-16-2017, 08:34 PM   #12
jdl71
jdl71's Avatar
Your axle is a Dana 44f, closed knuckle but I don't know how much difference that makes. I have a 66 k20 that should still be original. I also replied to your classified post, I will take some pics when I tear into mine, but I'm not sure when that will be.
Psalm 23
64 C10
jdl71 is offline   Reply With Quote
Old 10-17-2017, 12:55 AM   #13
Short 3/4
Active Member
Thanks, saw your other post
292-SM420-T221
Old 10-17-2017, 01:06 AM   #14
Short 3/4
Active Member
Thanks for the picture, is a lot better than the one in my book. Looks like everything is the same as mine, so should be helpful.
292-SM420-T221
Old 10-17-2017, 01:13 AM   #15
Short 3/4
Active Member
Unfortunately this looks to be for 11 inch brakes. 12 inch is the same but everything is just a little bit longer. Looks like P.O.used parts from this kit on last brake job and made a real mess of things.
292-SM420-T221
Old 10-17-2017, 03:01 PM   #16
61K10
61K10's Avatar
Did they even have self adj on the 12" brakes? Or on a closed knuckle dana44?
1961 chevy K10
Old 10-17-2017, 08:33 PM   #17
jdl71
jdl71's Avatar
According to the FSM, yes.
Psalm 23
64 C10
Old 10-17-2017, 08:39 PM   #18
franken
Just a suggestion so don't kill me. Over on Pirate they have kits to convert to disk that typically use mid-70s 3/4 ton front callipers and rotors.
Assuming the brackets are available for a closed D44, I see no downside other than drum wheels may hit the calipers.
Old 10-18-2017, 01:42 PM   #19
61K10
61K10's Avatar
I put disc on mine (closed knuckle 44 6 lug) I have 16" by 6" wheels that fit and a set of 15"x8 that fit. Don't have any stock wheels to see if they fit though.
Maybe the hole (for the adjuster) in the 12" brake shoe in lower than the 11"?
1961 chevy K10
Old 10-18-2017, 03:39 PM   #20
61K10
61K10's Avatar
This is for a 64-72 chevy 2wd 3/4t from classic truck parts # br1610 left. different than 1/2t. don't know if 4wd is the same.
1961 chevy K10
Old 10-19-2017, 12:20 AM   #21
Short 3/4
Active Member
Unfortunately is the same application as post #11, which is for 11 inch brakes or rear of K20. I have all parts for a K10 front and they are smaller. P.O. tried to make these parts work on front with very bad results.
Thanks to all who are trying to help me on this one. Tom
292-SM420-T221
Old 10-19-2017, 12:47 PM   #22
61K10
61K10's Avatar
this is for 12"x2" brakes but does say rear spicer. not 11" Dodge/IH/ford have some for 12"x2" shoes but use a cable instead of a rod. Pictures on rockauto. good luck
1961 chevy K10
Old 11-08-2017, 02:59 AM   #23
Short 3/4
Active Member
Appreciate all the help, but still no luck. Any body else ?
Thanks, Tom
292-SM420-T221
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
