Old 09-20-2016, 01:26 AM   #1
GSP7
Zddp oil additives
Who's running one of the zddp (zinc/phosphorus) additives in your oil for your older classic rebuilt flat tappet(lifter) cam engines
Since they are taking zinc/phosphorus out of all oils because it wreaks catalytic converters etc
Ive been doing alittle research, the brands I've found are :
ZPPD plus http://zddplus.com/
ZPPD max http://www.zddpmaxx.com/
Lucas http://www.jegs.com/i/Lucas-Oil/639/...FVBlfgodX6oDbA
'81 K20 Silverado ,
'99 Dodge Cummins 4x4
Pinstriping-Lettering-Specialty Painting
https://www.instagram.com/ricksspeedandcolor/
GSP7 is offline   Reply With Quote
Old 09-20-2016, 10:09 AM   #2
TJ's Chevy
Chevy I6 and GMC V6 Nuts
TJ's Chevy's Avatar
Re: Zddp oil additives
I am currently running plain Napa 0w-40 in my 305 v6. Going to add the Lucas break in zinc shortly. The Best thing you could do is purchase a good oil like Gibbs, Pen, or Royal Purple, and best of all Amsoil. They have zinc in them and all have great reputations.
"6 in a row makes it go!"
"I prefer a buzzin half-dozen"
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 09-20-2016, 12:02 PM   #3
cg285
kendal super D xa
cg285 is offline   Reply With Quote
Old 09-20-2016, 02:56 PM   #4
D.PASSMORE
One of the First
D.PASSMORE's Avatar
I read this article (below link) and it changed my mindset about the ZDDP debate. I ran Rotella 10/30W semi/synthetic with ZDDP. I lost a flat tappet CAM recently and going in this direction with engine oil for my older vehicles. Its a PIA to have to R&R good running motor for the last 75/80K miles because of lubricants standards.
https://540ratblog.wordpress.com/
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 09-20-2016, 03:07 PM   #5
cg285
i replaced a fair amount of worn camshafts back in the 60's-70's - long before the zddp was eliminated
Old 09-20-2016, 04:00 PM   #6
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Amsoil is the best. Use the flush if not running synthetic now.
Clyde65
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-20-2016, 04:45 PM   #7
GSP7
Alot of good information here: Tech Briefs http://zddplus.com/about-us/tech-briefs/
I talked to Howard, the guy that wrote all the Tech Briefs. Very informative guy
First one I read was "Diesel Oil Use in Classic and High-Performance Gasoline Engines"
I know guys running Diesel oil like Delo and Rotela in their Gas Race motors. Not necessarily a good idea.
I agree Brad Penn oil is good stuff. But its around $9.00 a quart
'81 K20 Silverado ,
Old 09-20-2016, 09:38 PM   #8
TJ's Chevy
TJ's Chevy's Avatar
I think Gibbs oil is around $7 a quart. My machinist swears by it.
Old 09-21-2016, 05:28 AM   #9
GRX
GRX's Avatar
I use some STP with my oil change. Still lists ZDDP on the label, though not sure the concentration these days.
Whatever you use, just remember that more ZDDP is not better. Too high levels can create a corrosive condition.
Oh my yes. Around the late 60s to early 70s many manufacturers were switching from flame hardening to cheaper electric induction processes. Often the middle of the stick would not heat properly with premature worn center lobes the result. Pontiac V8 were particularly prone since they had double valve springs & higher pressures straight out of the factory.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 09-21-2016, 06:52 AM   #10
Clyde65
Clyde65's Avatar
This is what Amsoil says about their ZRod motor oil.
AMSOIL Z-ROD Synthetic Motor Oil is specially engineered for classic and high-performance vehicles. It features a high-zinc formulation to prevent wear on flat-tappet camshafts and other critical engine components, along with a proprietary blend of rust and corrosion inhibitors for added protection during long-term storage. Z-ROD Synthetic Motor Oil is designed to perform on the street and protect during storage.
Amsoil is designed not refined!
Clyde65
support our troops!
Old 09-21-2016, 08:03 AM   #11
cg285
most i remember were sb chevys. i worked for pontiac dealership for about 10years but don't remember replacing any cams. timing chains, water pumps and 301 crankshafts were the norm
Old 09-22-2016, 05:01 PM   #12
Ironangel
Ironangel's Avatar
Interesting read! I'd like to know more about these high caliber additives. I was just reading a blog on the dynamic effects of molybdenum disulfide powder (1.5 micron) when added to crankcase oil. Much the same claims as this "Oil Extreme" additive. My newest vehicle, a 91 Jeep Cherokee with nearly 600,000 miles on it would make a nice test bed since that 4.0L motor refuses to die! Whats kept it alive? Rotella T changed regularly, period! I've known about ZDDP and the unique properties of zinc under high load high heat conditions for years. Like asbestos, nothing else can do what zinc does under certain extreme conditions. After reading 540RAT's blog Rotella T is in fact what it's claimed to be and even better now than ever with sustaining test results. I knew it was a good oil, I also knew that it's life span was short because it's conventional dino formulation and inability to resist thermal breakdown. So at $11 per 5qt jug, every vehicle on my property has Rotella T in it's crankcase and has had for years. From a 1952 Ford 8N to my 11.5 sec. 1980 Kawasaki KZ-1000 ST with the legendary MK-II Z1 1015cc motor. "Still breakin them Hardley Hearts!" ~Ghostrider~
Michael Hill, "Ghostrider"
1980 KZ-1000 ST-MKII, "Baby Doll"
72 Chevy C/10 SS-396 w/Comp Cam=268H, Closed Chamber 290 heads, Stage-4 Power Pack (Eagle Red's) 350THM, Beefed up 12-Bolt, Eaton 4:56 Posi, (Diesel Killer) Street Rod LWB "Nasty Sally"
72 Chevy C/10 Rebuilt 350 w/Voodoo-10120701 Cam, Stage-4 350THM, Beefed up 12-Bolt 3:73 Eaton Posi, LWB Wood Bed, (Daily driver, work horse) "Belle"
[url]https://www.facebook.com/michael.hill.12979[url]
Ironangel is offline   Reply With Quote
Old 09-22-2016, 11:23 PM   #13
T and S
T and S's Avatar
using Mobil 1 10W - 40 high mileage. It will either live or die with this oil, not worried about it.
If you don't like this pound sand .....
T and S is offline   Reply With Quote
Old 09-23-2016, 12:29 AM   #14
GSP7
From what I read and what Howard told me also is any corrosive issues is only with a super high amount. Like 50ppm. We dont even get close to that at 12-15-19 ppm
I like Chevron Delo, and chevron still shows the zinc/phosphorus amounts in the product data sheet. Shell doesnt. They are both great oils
'81 K20 Silverado ,
Old 09-23-2016, 10:12 AM   #15
kaycee
kaycee's Avatar
Valvoline VR-1 sold in most stores ,don't fall in to the pyramid scheme of some oils .
2001 Silverado K-1500
2005 FXDWG stage2
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60/3:36
kaycee is offline   Reply With Quote
Old 09-23-2016, 10:24 AM   #16
GSP7
Did ya here Commifornia govenor Moonbeam Brown banned Valvoline VR1
They just passed a law in Ca. banning certain API rated oil
Even amazon wont ship VR1 to Ca
I expect Valvoline will reformulate it for a "legal' api rating
'81 K20 Silverado ,
Old 09-23-2016, 08:36 PM   #17
kaycee
kaycee's Avatar
Another reason to stay out of Ca.
2005 FXDWG stage2
Old 09-27-2016, 04:37 PM   #18
GSP7
I called Valvoline tech . VR1 Valvoline is not banned in Ca.,,, Its just a internet hoax, is what the tech told me. The API ratings for VR1 are approved for commiefornia
The tech says anyone refusing to ship VR1 to Ca. (Amazon) is misinformed and wrong
I had some dude that owns a HotRod shop tell me that Delo and Rotella have zero ZPPD content because of the epa laws. Of course he is wromg. I called chevron and confirmed that also. Even Chevron's up to date Product Data sheet shows DelO is Zinc/phosphorus- .13/.12
'81 K20 Silverado ,
Old 09-29-2016, 03:24 PM   #19
shortbed70
shortbed70's Avatar
I run brad penn oil in mine. Supposed to be high zinc!
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 10-02-2016, 04:59 PM   #20
orbot
orbot's Avatar
uve ran ams oil and now im putting mobil synthetic
orbot is offline   Reply With Quote
Old 10-03-2016, 04:46 PM   #21
slowGN
slowGN's Avatar
I've talked to Richard Clark about this a few times. I know he has his hands in the making of Zplus, but I trust what he says. He is a stand up guy from what I know. I have been to his shop many times. I use it in my GN and C10.
Some of the products out there have it in them but not enough to do what its suppose to do.
slowGN is offline   Reply With Quote
Old 10-06-2017, 02:58 PM   #22
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I have a recently rebuilt 283, but I don't know how it was rebuilt and with what parts, so I was searching additives and came across this thread. - subscribed for reference.
66 Service truck build:
Old 10-07-2017, 10:16 AM   #23
LostMy65
LostMy65's Avatar
I found this in another forum :
http://www.impalas.net/forums/#/topics/6867
Old 10-15-2017, 07:09 PM   #24
toolboxchev
VR1 and not ever look back.
toolboxchev is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
