Old 03-04-2017, 03:09 PM   #1
63frankintruck
Water pump for L31 with Serp
Installing aftermarket reverse flow water pump with serp system
Problem------original water pump pulley for serp system has different bolt hole pattern than new aftermarket pump (see pics)
Anyone ran into this issue and have any solutions?
Sorry pics rotated, not sure how to correct this
63frankintruck is offline   Reply With Quote
Old 03-04-2017, 03:50 PM   #2
B. W.
B. W.'s Avatar
Re: Water pump for L31 with Serp
the stock pulley has a larger center bore & bolt pattern because the fan clutch screws onto the water pump hub rather than using the four bolts to hold it on
B. W. is offline   Reply With Quote
Old 03-04-2017, 05:14 PM   #3
James the III
you have a standard reverse rotation pump on your l31 , the truck is the same other than the hub and fan mount..
This was done, because of passed issues of people installing the wrong rotation pump on cars .. This set up, you get the pump and go that isn't the same..
I'll bet they make a pulley for the car pump that works with that whole set..
So you don't have to replace the pump.. as long as that pump IS a reverse rotation..
James the III is offline   Reply With Quote
Old 03-04-2017, 08:29 PM   #4
63frankintruck
The pump I purchased is a standard reverse rotation.
This one
https://smile.amazon.com/dp/B01L0YPH..._prd_ttl_sol_0
Old 03-04-2017, 08:51 PM   #5
Bigdav160
Bigdav160's Avatar
TBI trucks ran reverse rotation also. I couldn't tell you if a TBI pulley would line up or not.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 03-05-2017, 01:01 AM   #6
Captainfab
60-66 Nut
The pulley you have is specific to the L30/31 Vortec water pump. What you need for your aftermarket water pump is a pulley for a '88-'95 TBI truck. I think it should line up with the other pulleys but I do not have experience with that to say for certain.
Old 03-05-2017, 12:33 PM   #7
James the III
call the maker of the set up.. I'll bet they will swap pulleys..
Old 03-05-2017, 12:49 PM   #8
Bigdav160
Bigdav160's Avatar
From the OP's pics, it appears he is using stock L31 brackets
BW has TBI brackets on an L31 motor.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 03-05-2017, 08:31 PM   #9
63frankintruck
Yes the brackets are from a TBI 350 motor I bought for parts (I was told that the motor was from a 97 Suburban)
Captian Fab - 85-95 TBI pulley I think is smaller diameter.
This is all I found so far-
http://www.jegs.com/i/Chevrolet-Perf...85760/10002/-1
Old 03-06-2017, 07:31 AM   #10
James the III
That don't matter.. other than pump speed.
you want it to have the same rib count(if aplical)/width as your other pulleys .
That part # above is for a bbc
GM Replacement Water Pump Pulley - 1987-1995 Chevy/GMC Truck 7.4L & GM Serpentine Drive Kits - Big Block Chevy
does not say gm serpentine drive kits- big and small block chevy..
I'd call and check first..
me I'd go get a pulley off a 1995-back tbi truck for 5 bucks at a junk yard..
as you need the balancer bolt and washer , the starter bolts (they are different thread /size than the 70's bolts) the dipstick tube and dipstick..
the coolant temp sender.. (threads and size is different than older engines.)
I even took the plug wire holders..
Old 03-07-2017, 12:02 AM   #11
Captainfab
60-66 Nut
The serpentine water pump pulleys are not ribbed. They are smooth since the back of the belt is wrapped around the water pump pulley.
I agree with just getting a '88-'95 TBI water pump pulley. The diameter is not that critical. The other alternative is to switch to the '96-'02 L30/31 water pump.
Old 03-07-2017, 05:50 PM   #12
B. W.
B. W.'s Avatar
pulley diameter on 5.7 truck TBI is 5.75", vortec is the same diameter. Bolt pattern on TBI is 2.0" O.C.
Old 10-04-2017, 08:32 PM   #13
kacy
kacy's Avatar
How did this turn out?
79 Corvette- 406/7004r Holley EFI
87 V10- 5.7L, Vortec heads, E110026, 410s 35s, 700r4
kacy is offline   Reply With Quote
Old 10-05-2017, 09:57 AM   #14
bluex
bluex's Avatar
I dont know what the OP did, but I have the L31 brackets on my 350 and I used a 88-95 water pump, pulley and thermostat housing. Its working fine, I have both the L31 and the TBI pulleys and the only difference between them is the center bore and bolt pattern. The diameter is the same.
Heres what I used and the year ranges
88-95
Water pump
Pulley
thermostat housing
upper radiator hose
96-99
Bracket set
Idler
Tensioner
Crank pulley
Power steering pump and pulley
A/c delete/compressor
Belt
2003 5.3L (suburban or tahoe with 145A option)
AD244 alternator
Lower radiator hose, heater hoses and power steering lines are stock parts from my 1978 C10. I swapped the pressure line fitting from the original pump into the L31 pump to allow me to use the factory line.
bluex is offline   Reply With Quote
Old 10-05-2017, 12:02 PM   #15
kacy
kacy's Avatar
88-95
Water pump
Pulley
thermostat housing
upper radiator hose
96-99
Bracket set
Idler
Tensioner
Crank pulley
Belt
AD244 alternator
Thanks for the info I was wondering if the TBI pump/pulley would line up correctly. AS for the power steering pump, I used the pump from my 79 vette when I added serp to it. It bolted on like it was made for it.
