Old 10-02-2017, 12:34 PM   #1
WestButteTruck
Kung Fu Master
WestButteTruck's Avatar
TH400/NP208 drivetrain fitment question
So, I have a lead on a rebuilt turbo 400 with a 208 case with a gear vendors attached to it. Is there any real fitment issues, or would this be a headache of sorts.
Also, is this combo something that works well together? I had planned on doing a 700r4 at some point anyway to obtain the OD. This is for a 72 1/2 ton 4x4. Thanks
72 GMC SuperCustom 4x4
1972 Chevrolet Cheyenne Super 4x4
WestButteTruck is offline   Reply With Quote
Old 10-03-2017, 10:20 AM   #2
B. W.
B. W.'s Avatar
Re: drivetrain fitment question
My only complaint with the GV is you can't run it in 4wd. It will leave you with a shorter drive shaft but I think that would only be an issue with a K5.
You may have to adjust your crossmember but it should bolt up with minimal fuss. (I have not done it)
B. W. is offline   Reply With Quote
Old 10-03-2017, 01:37 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Do a search on "Gear Vendors overdrive". There have been some posts in the past that may help. Also, you may be able to message the members that have used them before to get their thoughts on it.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 10-03-2017, 03:25 PM   #4
Tiger Joe
i would wonder, and I don't know the answer to this, but wouldn't the GV hanging off the back of the t case be very close to or actually cause interference with the trailing arm crossmember?
Tiger Joe is offline   Reply With Quote
Old 10-03-2017, 08:35 PM   #5
B. W.
B. W.'s Avatar
IDK but the OP's truck is 4x4 so it's leaf spring.
Old 10-03-2017, 11:38 PM   #6
Ironangel
Ironangel's Avatar
I'll trade you a balanced correct length drive shaft for the gear vendor when you swap in the 4-speed...
Michael Hill, "Ghostrider"
1980 KZ-1000 ST-MKII, "Baby Doll"
72 Chevy C/10 SS-396 w/Comp Cam=268H, Closed Chamber 290 heads, Stage-4 Power Pack (Eagle Red's) 350THM, Beefed up 12-Bolt, Eaton 4:56 Posi, (Diesel Killer) Street Rod LWB "Nasty Sally"
72 Chevy C/10 Rebuilt 350 w/Voodoo-10120701 Cam, Stage-4 350THM, Beefed up 12-Bolt 3:73 Eaton Posi, LWB Wood Bed, (Daily driver, work horse) "Belle"
[url]https://www.facebook.com/michael.hill.12979[url]
Ironangel is offline   Reply With Quote
Old 10-04-2017, 11:47 AM   #7
WestButteTruck
Kung Fu Master
Well, I never thought about the 4 wheel drive issue. I think I will just go with an overdrive transmission. Thanks for the responses.
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
