Old 10-05-2017, 05:02 PM   #1
Jered1987
Jered1987's Avatar
86 k10 bad runner
Hey guys ive got a problem the 86 k10 i have has 350/th350 combo my problem is it wont idle like how most will jump their rpm until they are warm and you can kick them down this you habe to keep revving to keep it running and it will barely i mean barely idle and shut off the second it shuts off. It has no hei, all emmisions have been removed and the engine is out of a 76 camaro i believe. Places to start? Missing springs parts i should look for?
Jered1987 is offline   Reply With Quote
Old 10-05-2017, 06:44 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: 86 k10 bad runner
Sounds like you're used to modern Fuel Injected vehicles that idle right when you start them. If the choke on the carb is missing or inoperative then the engine won't run and idle during cold starts. You will have to keep feathering the throttle to keep it running.
Also ensure your timing is correct.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
GASoline71 is offline   Reply With Quote
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
