Old 10-08-2017, 01:19 PM   #1
Thebroski138
New carb for a 250 L6?
Recently I've started to notice some hiccups in the performance of my carburetor so I've decided to buy a new one. The only thing that I am stuck on is do I buy another 1 barrel or a 2 barrel? What are your opinions/experiences with these?
Thebroski138 is offline   Reply With Quote
Old 10-08-2017, 03:35 PM   #2
Lugnutz65
Lugnutz65's Avatar
Re: New carb for a 250 L6?
Use the search function and look for Weber carb setups. They are progressive 2 barrel carbs that will bolt to your inline 6 manifold with an adapter. Youíll need to convert to a cable style gas pedal and throttle cable.
Tom Langdon sells the parts youíll need. Look around on his website. LINK HERE
I had my Rochester B one barrel carb rebuilt and Iím pretty happy. Starts up easy and has done well. I think my HEI distributor has helped a lot too.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 10-08-2017, 07:00 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Be aware of local auto parts store rebuilt one barrel carbs. They are pieced together from multiple units and sometimes dinged pretty bad. I haven't had luck with them in the past and decided to start rebuilding them myself. I keep two or three used but good units in my garage just for that purpose.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 10-08-2017, 07:16 PM   #4
Lugnutz65
Lugnutz65's Avatar
I agree with 68gmsee. Best bet is to find an original that needs rebuilding and rebuild yourself or send to a shop that will rebuild YOUR carb. My 1965 carb still had the original Rochester tag.
Old 10-09-2017, 12:35 AM   #5
TJ's Chevy
Chevy I6 and GMC V6 Nuts
TJ's Chevy's Avatar
2 barrel holleys or webers are good choices. 2 barrel weber 32/36 is a decent choice.
"6 in a row makes it go!"
"I prefer a buzzin half-dozen"
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 10-12-2017, 06:39 PM   #6
Backpayne
I have the Weber 32/36 and have been quite pleased with it. If I knew anything about carb tuning I would probably be even happier with it.
Backpayne is offline   Reply With Quote
Old 10-12-2017, 06:45 PM   #7
Lugnutz65
Lugnutz65's Avatar
What kind of MPGs are you getting?
Old 10-12-2017, 06:51 PM   #8
Backpayne
Last time I paid attention was right around 15 mpg.
Old 10-13-2017, 01:29 AM   #9
'68OrangeSunshine
'68OrangeSunshine's Avatar
Fifteen MPG is pretty good for a half ton of tin and the aerodynamics of a brick.
Thread Tools
Display Modes
Copyright ©2000 - 2018, vBulletin Solutions Inc.
