Old 10-09-2017, 12:56 PM   #1
MMricky
71 burb reduced power
I have 71 c10 suburban with original 350 , rebuilt, sort of. Not confident that it was done correctly as it still has white smoke coming out of tailpipe. Itís been running fine for the 2 years I have had it, recently got the oil changed and topped off trans fluid and now after about30 minutes of run time itís like a switch I get reduced power. The more gas I give it it just wats to stall, oil pressure is good and trans shifts as normal just wonít go. Donít know if it is motor, trans, fuel issues. Just canít figure it out, it always starts, just happens after itís run for a while. I have 700r auto trans with edelbrock 4 barrel, mechanical fuel pump, running no ethanol in gas, spark is electronic being no points, just not sure how to diagnose any help would be much appreciated
MMricky is offline   Reply With Quote
Old 10-09-2017, 03:16 PM   #2
geezer#99
geezer#99's Avatar
Re: 71 burb reduced power
First thing to check whenever you have a no power situation is your timing.
Make sure the distributor hasn't moved and you have at least 12 degrees initial timing.
Other things to check is for vacuum leaks.
And it's possible your module in your distributor is starting to die.
geezer#99 is online now   Reply With Quote
Old 10-09-2017, 03:48 PM   #3
MMricky
Thanks for the info thatís where I will start
Old 10-09-2017, 07:24 PM   #4
garyd1961
Change all the fuel filters including the one in the carb if it has one. If you shut it off for a minute and start back up what does it do?
garyd1961 is offline   Reply With Quote
Old 10-10-2017, 10:26 AM   #5
68gmsee
Active Member
68gmsee's Avatar
Agree with above recommendations.
When you have a sudden loss of power it's always a good thing to start a checklist and do the easiest and cheapest first.
-Timing
-Vacuum leaks
-Filters (including breather and carb inlet filter)
-Bad fuel pump or fuel restriction (fuel pump should produce 1 pint of gas in less than 30 seconds into a plastic container.)
Other things include compression check -maybe a leak down test since you mentioned white smoke out of the tail pipe. If it's not normal condensation it could be sucking in coolant or maybe transmission fluid.
If all the above checks out, carb may need to be checked. On high mileage engines a worn cam would give the same symptoms but it would be gradual.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 10-10-2017, 03:01 PM   #6
kwmech
Sounds like it may be constipated if it progressively gets worse. Check for a restricted exhaust system, plugged muffler etc
Old 10-12-2017, 03:44 PM   #7
MMricky
Looks like it is a vacuum line, so far running better but I will start going through the list of other suggestions, the guy I bought the vehicle from said he had rebuilt the motor and it had 12k on it, not confident with the work but it has always run. Thanks for all the feedback
Thread Tools
Display Modes
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
