06-12-2014, 12:33 AM | #76 |
60-66 Nut
Re: 400/406 Builds
Thanks for posting flips72
I am anxious to hear what the dyno says.
08-07-2014, 11:47 PM | #77 |
60-66 Nut
Re: 400/406 Builds
Anyone have any new builds to post?
08-08-2014, 05:00 AM | #78 |
Re: 400/406 Builds
After reading everyones i figure i will put mine up here. Just pulled it out yesterday of my 68 camaro. The motor is a 406, 511 block, currently with pbm heads, rpm air gap, comp roller cam, roller 1.7 roller rockers, eagle rotating assembly and a quick fuel 750. There where a couple of reasons i pulled it and it will soon be turned into a 408.
First, has always smoked with oil blow-by. Has little to no miles on the motor and im pretty sure that the machine shop that did the short block will not see another dime of mine. Seems like the rings never did seat. I dont know if they said they checked/honed it or nothing at at all but has always used the oil. The header gaskets i just pulled off backed all that up. Anyways reason #2 is more my fault and i kick myself for doing it, but my first time assembling a motor so you live and learn i guess. I reused the old head bolts when putting the heads on and regular old fel pro gaskets. (not the good performance ones that will soon be on it.) I had one or two bolts that would not torque down all the way and thought that it would be ok. Well as of late it had been running hot and i could not figure out the reason. Awhile passed since i had been able to mess with it, went to start it and nothing. Locked up tighter than dicks hat band. Wasn't the starter and when I tried to roatate it by hand at the crank nothing. I started pulling plugs and when i got to #5 water poured out like i had just drilled a hole in a freeze plug. I am taking the little turd to a much better shop from what i have researched Monday morning. Where it will be done right. I'm going to have them check the heads and block, take it to a 408 (if its still good which i hope it is), up my compression to around 10:1; install head studs and 1014 felpro gaskets (which I have both, brand new), balance my rotating assmbly. Then send it to a few good ole boys i used to work for down in TN who now own and run Dyno engineering to break it in and tune it correctly before i get it back. My wife told my buddy that helped me pull it out that she had never seen me cry but when i realized that it had locked up and needed to be pulled out, she swore she saw a tear.
Chad '68 Camaro - 408 sbc, Muncie m20, 9' rear, hotchkis supsension (aka Betty) '72 C10 - pretty much all stock as far as i know, for right now anyways (aka Charlie) |
08-08-2014, 09:41 AM | #79 |
Re: 400/406 Builds
Dont force it to turn over. There is a good chance that you are lucky and no damage was done to the rotating assembly. Flip the motor upside down and pull the oil pan. Loosen all the main bolts and every rod that you can. Now try an bar it over to disassemble. I have worked on a couple of motors like this and had no permanent damage. One had an oil leak and the idiot was adding oil to the windshield washer fluid! Got the truck for free because of the locked up motor. Did the above and never replaced a single peice. Bolted it back together and ran that motor for 5 more months in 120 weather without issues. I have a small project v6 that was locked up by the owner running 40wt oil in it. Came out in 20* weather to start it and only got a click. Tore it down and there was zero damage. That one will get a full rebuild one day before sliding it into a new ride, even though it is fine.
08-08-2014, 11:29 AM | #80 |
Re: 400/406 Builds
the head bolts wouldn't torque and you just left it?
there's no need for head studs - just get the right bolts and make sure the holes are clean with a cleaning tap...the shop that built it should have done that. don't blame head bolts or the gasket for your decision not to fix an assembly problem... |
08-08-2014, 02:40 PM | #81 |
Registered Truck Offender
Re: 400/406 Builds
The deck on the 511 casting is thin to begin with. If someone 'cleaned the threads' with a standard tap.... and old corroded bolts were used.... good chance he pulled the threads out of the deck. New bolts or studs ain't gonna fix that!
The 400 deck and bolt holes are a weak link for sure, Here's a 509 casting that was making just over 650 at the crank, was pushing the head up hard enough to pull the deck, cracking it from the bolt to the water ports and it pinched the piston enough to turn it to junk. Sometimes 'studs' work too good LOL http://www.small-block-chevy.com/ima...0/400blk_a.jpg http://www.small-block-chevy.com/ima...0/400blk_b.jpg Think maybe we discussed this early in this thread (or in another),, sorry if it creates an echo
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
08-08-2014, 07:04 PM | #82 | |
Re: 400/406 Builds
if the threads pulled it was even worse because there was no way it would seal - but if the head had been pulled no matter what was wrong could have been caught and fixed...just leaving it was a bad call, no matter what the issue was. im calling it out so people can learn from it - that's it. Last edited by DBD; 08-08-2014 at 07:10 PM. |
08-08-2014, 07:32 PM | #83 | |
Re: 400/406 Builds
08-08-2014, 07:41 PM | #84 | |
Re: 400/406 Builds
I don't know if the machine shop did anything wrong - the smoke could be coming from the heads or rings...without a leak-down it's hard to say, and you could have had head gasket sealing from the get-go...so the smoke could have been from that...plus running it when it was overheating (probably also part of the head gasket sealing problem) probably led to the final failure. if the bore was full of water then there are all kinds of issues. post a pick of the head gaskets and the bores and lets have look. I ain't trying to be hard on you - but engine building is pretty unforgiving. I guess i'm just not ready to blame the shop based on what you wrote, but I hope you have better luck with the next build - just take it slow and do everything just right Last edited by DBD; 08-08-2014 at 07:55 PM. |
11-27-2014, 10:33 PM | #85 |
60-66 Nut
Re: 400/406 Builds
Anyone building a 400/406 this Winter?
03-30-2015, 12:42 AM | #86 |
60-66 Nut
Re: 400/406 Builds
Any completed 400/406 builds or new builds going on?
07-09-2015, 12:22 AM | #87 |
60-66 Nut
Re: 400/406 Builds
Anyone with a new engine build to add?
07-09-2015, 11:34 AM | #88 |
Re: 400/406 Builds
here is what I am working with -
Dart Short block 400 (03114002) AFR 195 or 210 head eliminator street head Howards OE style lifters (91113) Howards Roller Cam either a 180885-10 or a 180265-10 Comp Ultra Pro Rocker Arms (1602-16) any more thoughts on the cam selections please feel free
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
07-12-2015, 12:42 PM | #89 |
Re: 400/406 Builds
Got my 408 back together and headed to the engine dyno on the 18th for break in and tuning. New speed pro pistons, 5.7 eagle rods, ARP head studs, and a set of Blue Print Engines Aluminum 195 heads. Should be a little of 10:1 compression. Lesson learned, trying to do it right this time.
07-14-2015, 09:57 PM | #90 | |
Re: 400/406 Builds
Tim K. 84 K30 srw Silverado 454 auto 85 C20 350 C6P auto flatbed 94 K1500 lifted shortbed 350 4 bbl NV4500 |
07-14-2015, 10:30 PM | #91 |
Re: 400/406 Builds
Thanks, will do. Hopefully ill get plenty of pictures and a video or two.
07-17-2015, 03:28 PM | #92 |
Re: 400/406 Builds
I am building a street/strip engine for my 64 Chevy II. Let me know what you think.
.40 over 509 block Comp 280h Scorpion 1.6 Rockers GMPP FastBurn Heads yielding approx. 11.2 compression Edelbrock Vic Jr Holley 750 HP TH350 with 3000stall What do you think of the cam selection? Any recommendation for better choice? I already have all of this on the shelf. Rusty
1984 C10 SWB Custom Frame Blow Through Carb Single Turbo Hope to be on the road by Summer 2018 1967 C10 CST LWB 327/PG Original Running Driving Future Project Last edited by ol84; 07-17-2015 at 03:42 PM. Reason: information |
07-18-2015, 01:13 AM | #93 |
60-66 Nut
Re: 400/406 Builds
The 280h is a bit of an old school grind by today's standards, but I totally understand the want to use what you already have. Have you calculated your dynamic compression to see if you can run the fuel that you want to with that cam? You may need a different cam or pistons with a dish to get your dynamic compression where you need it.
07-20-2015, 08:45 AM | #94 |
Re: 400/406 Builds
Back from the dyno the other day. Brian and Chris at DynoTune Engineering in Paris, TN are great to work with and anyone local that is wanting to dyno their motor I would recommend them. We went through a couple different setups and I ended up with 445 HP and 485 ft/lbs of torque. Not breaking any records but I'm pretty pleased with it. Should be fun in a little 4 speed car.
07-20-2015, 09:54 AM | #95 |
Re: 400/406 Builds
Should be a great combo 68nou1.
I ran the numbers and seems my compression is higher than I would like. A little more research to be had on my end on DCR. I could bump up to a larger comb chamber (72cc-76cc) head and that might solve the problem. Definitely want it streetable. My 84 C10 engine is a beast and I want this to more street friendly. What kind of cam profiles does one look at to bleed off DCR? Thanks, Rusty Posted via Mobile Device |
07-20-2015, 10:34 AM | #96 | |
Re: 400/406 Builds
Can you give us the cam specs you used?
07-20-2015, 11:20 AM | #97 | |
Re: 400/406 Builds
07-20-2015, 05:54 PM | #98 | |
Re: 400/406 Builds
99% of these miracles in a bottle are nothing but Toluene and Zylene and they have a dramatically reduced effect on the 10+% ethanol fuels at the US pumps today. Only thing 'I' know of to make a true 95+ octane (MON,, no one cares about RON or the 'pump' names),, Here's what I mix up for my 11.5:1 sand buggy. 5 gallons of VP C-12 (108 motor octane and 4.23g lead per gallon) + 10 gallons of Pump 91 (most is motor octane of less than 89) mix well and enjoy with a frosty glass of iced-T BTW here's some interesting reading on blending octane boosters with pump fuels. You have to make believe you understand the technical crap and the references to the Aussie fuels, but interesting stuff starting around page 16
08-07-2015, 10:56 PM | #99 |
Re: 400/406 Builds
Sorry it has taking me so long to get back with the specs. Been laying hardwood after a water leak and taking care of things around the house. Anyways the cam is a Comp xe274h 230/236 @ .510/.520 lift with 110 LSA
08-26-2015, 01:05 PM | #100 |
Re: 400/406 Builds
Im in the early stages of putting one together for my 47/S10 build. somewhat low buck build.
2 bolt .020 over 400. dont remember casting number. fully rebuilt and ported cammel backs. 292 I believe ported, cast 327, holley flange stock intake 2 inch ram horns for now, 2 1/2 if I find a set for cheap. Not sure on cam yet. open to suggestions 600 vac secondary holley Not looking for a full race motor but would be happy with 400HP. Not sure if I will get there with that intake and exhaust but will see what happens. the truck will only be around 3000 pounds so it wont take much to be quick. Nick |
