11-04-2016, 10:53 AM | #1 |
Brake lines
Ha all doing my buddy at favor he asked if I can replace is brake lines on his 53. Well he went and took all the old stuff off and now I'm left guessing where the new ones go. I was wondering is there a pic somewhere to give me a shot at getting this done? He's and old schooler and doesn't have a cell phone yes I said it no phone no pics any help would be great
11-04-2016, 12:09 PM | #2 |
Re: Brake lines
Factory Assembly Manual shows how they are routed. Unfortunately I do not have one for an AD truck, maybe someone will post up the page or photos from their build.
11-04-2016, 01:54 PM | #3 |
Re: Brake lines
Ya that's what I hope it sucks like putting a puzzle together
11-04-2016, 04:41 PM | #4 |
Re: Brake lines
try orrieg's link to the old car manuals project.
does he still have the single circuit master cylinder? may want to update that for him while you are at it, for safety. his and everybody else's |
11-05-2016, 02:35 PM | #5 |
Re: Brake lines
for original single master cyl,
There is a T at the rear of the master cylinder. run a line forward to the left rear of the front crossmember, then install a T there. run short line to the left and one to the right wheel along the rear of the crossmember.....go to the hardware store and buy rubberized clamps if the original stuff is trash. For the rear, go back to the master cylinder, and the end of the t that's open, run a line on the right inside of the truck frame back to just before the edge of the tire, and put a one foot flexible line to that line, anchor it there.then run a line from there to the rear axle midway between the pumpkin and the right rear backing plate. install a T there. Then install the lines to each rear cylinder. anchor the lines so they don't vibrate and wear. the front lines go through the frame near the axle where it crosses under the frame. the rear lines anchor to the rear axle.
http://http://67-72chevytrucks.com/v...d.php?t=489721 Last edited by Coupeguy2001; 11-05-2016 at 02:44 PM. |
11-05-2016, 03:02 PM | #6 |
Re: Brake lines
here are some pics of the rear brake lines as stock routing.
11-05-2016, 03:14 PM | #7 |
Re: Brake lines
here are a couple more showing actual original equipment routing. more to come, only allows 2 at a time for some reason.
11-05-2016, 03:14 PM | #8 |
Re: Brake lines
a couple more
11-05-2016, 03:17 PM | #9 |
Re: Brake lines
last of that group. hope it helps.
11-06-2016, 12:07 PM | #10 |
Re: Brake lines
Thanks for the photos that's a big help
