05-10-2013, 06:17 PM | #1 |
Need some real numbers, MPG...
I have been following a few peoples' build threads and I am looking for some good solid numbers on economy. I'm talking daily driven, mixed, hwy, city, anything. Also, how the truck and engine is configured. I have an '83 4x4 3/4Ton and it will be getting an LQ4 and an NV4500, might even regrear it from 4.10 to 3.73. I am trying to estimate what my economy will be. My intent is to inject it with a 4bbl manifold drilled for injectors, and an air-only throttle body on it. Maybe a mild cam, looking at the SDPC HT1 cam. Specs: HERE Also, LQ9 flat top pistons are a possibility.
I am sure, going from the old carb'd 400sbc to an LS will be a big change and there will be a period of time when the skinny pedal gets a workout, but I am really interested in what kind of economy these engines are getting in our old iron.
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
05-10-2013, 07:06 PM | #2 |
Re: Need some real numbers, MPG...
I get 17 mpg average on my C20 Burb with a 5.3/4L60E, 6.0L & yours being 4x4 will be lower, Im guessing around 13-14mpg as a realistic average.
05-12-2013, 09:25 AM | #3 |
I'm in the process also of putting in an LS in a 2wd 70. However my 67 with a fairly healthy 408 smallblock and a 700R4 with 3.42 gears knocks off 17 on the hwy.I'm going the LS way just because I got a whole low mileage 2000 truck for $600. It's just cheaper for me. Your mileage will increase but not by a huge amount.If your drivetrian is in good shape now I wouldnt do a LS swap completely based on fuel mileage.But an LS sure runs nice.In my opinion the symplicity of your current setup is worth something too.
05-19-2013, 04:11 AM | #4 |
Anyone else? There are a ton of our classic steel trucks rolling around with LS mills...they finish their builds and quit reading this section?
05-19-2013, 05:37 AM | #5 |
It's alsways something.....
One of the issues, especially with the earlier models (mine is 71 blazer) is that a lot of us are cruising around with LS power, but don't have a working speedometer/odometer. A board member has figured a solution and many are getting started adapting a S10 electric speedo into the 67-72 instrument panel. Stay tuned, MPG info will be coming when the ability to calculate becomes available.
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e |
05-19-2013, 01:11 PM | #6 |
meowMEOWmeowMEOW
I get 13-15 local and up to 17+ on the highways locked up around 60. I have a decent amount of drivetrain to turn, so I think the numbers are decent all things considered. Once I'm not running drag radials on the back, my mpg will go up a tad too.
05-19-2013, 02:48 PM | #7 |
chuckmc8, I saw that cluster thread and it is fantastic. There is a lot of work that went into it and I think it is great that 67-72 has such a OEM looking solution. 81+ has one from the factory with the 90-91 V-series clusters, they technically fit back to '73 but are cosmetically incorrect.
BR3W CITY, say your build recently, great looking truck. Next to my '83 I spent a lot of time with my dad in his '65 on the farm, such a great truck.
05-23-2013, 04:38 AM | #8 |
Bump
05-23-2013, 12:57 PM | #9 |
Truck and auto performance nut
My 4600-4800lb TrailBlazerSS with 4.10 gears gets 12 around town, 14 average, with 16-17mpg being about tops for any highway mpg at 70+.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
05-23-2013, 02:10 PM | #10 |
I daily drive my truck. It's a 1985, 3/4 ton, long bed, lifted with 33 inch tires and 4.10 gears. I have a stock 5.3 hooked up to the stock th400. I get 11 mpg.
My milage is bad due mostly to my gears, 3 speed trans, and tires. It's better than the 7 mpg I was getting from the stock 350 though. When I put an overdrive trans in it, that should help a lot. |
05-24-2013, 08:13 AM | #11 |
1965 Chevy C10, 2005 4.8L/4l60
I have a 4.8/4l60e in my 65 and I get an average of 15 city and 19+ hwy. I have gotten 20.5 when there wasnt much wind. these are at 65 and I dont hot rod my truck ( why would i with a 4.8 right?)
If mileage is what your looking for in a big truck like that get a Cumins and a nv4500 with propane injection. your truck is huge and you unfortunately wont see the mileage most of the ls is known for for swaps.
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
05-24-2013, 11:11 AM | #12 |
I will be able to report back after we start on the power tour. In stock form I did pretty good 18 - 20 but after a cam it dropped now I have a turbo but I am hoping that doesn't hurt during normal highway driving. I have also added a T56 but lowered my rear gear to 4.11:1. Time will tell.
These trucks are heavy and the frontal area is huge, the drip rails don't help matters any. Realistically I would love to pull over 20 mpg and it might be possible but speeds over 70 I am afraid we will run into that wall. I believe I have things dialed in good for this trip but again with my weight I bet I will still suffer.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
05-24-2013, 11:27 AM | #13 |
Im getting right around 20 in mine, its stock and i drive like a granny...lol 65 tops in most cases, and a lot of back roads at 50ish.
68' c10 stepper 5.3/4L60e Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=578917 |
