08-25-2018, 11:51 AM | #1 |
th400 bolt in to slip in
I have a th400 with a bolt in style yoke I know there is a counterbored yoke that allows the use of a slip in style but $100. A machinist friend has a lathe and a 6 pack will get it done . Does any one have the dimensions for the counterbore or how deep? some say that I still need to add a o ring to the tailshaft? any input appreciated. TY
08-26-2018, 07:17 PM | #2 |
Re: th400 bolt in to slip in
No one???
08-26-2018, 08:36 PM | #3 |
there is different shaft styles for each yoke system . the yoke also can be reworked if you have the specs .
i know a guy who has a th400 that was bolt on yoke now slip on . but the problem is he has not got the correct tail shaft in the case and it weeps oil since the correct shaft would have a grove to hold a oring to seal the slip and splines from leaking fluid past it . if your trans has this then your prob good to go . if not then try it and see what you get .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
08-26-2018, 08:40 PM | #4 |
Years ago I ran a 400 with a bolt on yoke in my Malibu. Car came with a 400, so just unbolted the yoke, and slipped the original on. Now on a car this is prolly OK, since the slip doesn't slip as much like it would in a truck. Ran it like that for 60k....
08-27-2018, 12:01 AM | #5 |
60-66 Nut
Why not just use the correct driveshaft with the slip yoke in it?
09-02-2018, 01:06 PM | #6 |
TY all
