Old 10-19-2018, 01:03 PM   #26
andyh1956
Re: No adjustment hole for rear brakes
I bet this is why people go to Disc Brakes in the rear!
andyh1956 is offline   Reply With Quote
Old 10-19-2018, 05:14 PM   #27
hatzie
Moderator
hatzie's Avatar
The 14bolt axles on my 76 & my T400 have the slots in the backer plates.
I'd leave the drum as-is for balance reasons... but I'm not above doing some amateur machining on the back plates with a cobalt drill bit and a file.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 10-19-2018, 06:30 PM   #28
Tom
driving is in my blood
Tom's Avatar
All my trucks have no backing plate hole for adjustment. You pull the drum, adjust, then install the drum and check. Pretty simple really.
Old 10-19-2018, 09:00 PM   #29
Bandit130
Bandit130's Avatar
Mine has the adjustment slot in drum accessed from outside. Have to rotate wheel to 6 o'clock position for adjustment. Do not need to remove wheel.
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is online now   Reply With Quote
Old 10-21-2018, 05:15 PM   #30
Pontiac1976
Pontiac1976's Avatar
Hiluxxulih's Avatar
This must be an oddball truck no knockouts to be found ., maybe Canadian trucks did not have them .
This Not a Canadian thing as Canada does not make break parts as (drums/rotor, pads/ shoes) or there all USA made out source to Asia to save money. The one with no hole you got are cheaper drums or your meant to pop out the knock hole.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
