Old 02-22-2016, 07:07 PM   #1
BT Classics
Question Borgeson Delphi 600 Power Steering with manual transmission?
Hoping someone has run into this issue and could help me out.
Working on a 1956 Chevy. Purchased a Borgeson Delphi 600 Power Steering box that was advertised as a conversion kit for the '56 (with modification to the steering column). The problem I'm running into is that the shaft from the clutch linkage is hitting the power steering rod.
I called Borgeson and they weren't sure if the power steering box or rag joint should be different for a manual clutch set up.
Anyone?
BT Classics is offline   Reply With Quote
Old 02-23-2016, 09:53 PM   #2
Longhornss
Re: Borgeson Delphi 600 Power Steering with manual transmission?
Pictures may be helpful.
Longhornss is offline   Reply With Quote
Old 02-24-2016, 07:47 AM   #3
PGSigns
PGSigns's Avatar
Seeing what and where it is hitting will help. If the rag joint is the problem, swappng it for a U-joint may cure it.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-03-2016, 07:26 PM   #4
BT Classics
Discovered that the Z bar was not sitting level and that the problem may be with the frame bracket. I cut the existing frame bracket off and will see if re-positioning it will help with clearance.
