Old 06-12-2018, 03:38 PM   #1
mattfranklin
mattfranklin's Avatar
Dumb Fuel Hose Question
The stock fuel line for my 1970 C10 is 5/16", but the fuel pump inlet is 3/8".
This is because I'm following the 1970 Corvette/LT-1/Z-28 stock specs for my parts.
I'm kind of a hack sometimes, so I know that I can probably just use a 3/8" hose and crank down on the hose clamp on the 5/16" line end. Or possibly I could stretch a 5/16" hose over the 3/8" pump fitting. Or I could make it ugly and put a double barbed adapter in the middle with one for each type of hose. I think any of those would work, but I'm wondering... Is there an existing molded hose available that would have a proper size for each end? It only needs to be around half a foot long.
Maybe I'm overthinking this and the 3/8" hose would be fine, but I did have an engine fire about 10 years ago so I'm a little gun shy about any risks under the hood.
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is offline   Reply With Quote
Old 06-12-2018, 06:39 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Dumb Fuel Hose Question
Get the new hard lines that are 3/8" and then use short pieces of 3/8" hose where you need it.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 06-13-2018, 11:21 AM   #3
ka_jd7and1
is a fungineer
ka_jd7and1's Avatar
If you want to keep the 5/16" hard line, you can also get a 5/16" compression by NPT fitting, and then a NPT X 3/8" hose barb, then run a short 3/8" hose to the pump.
2003 S10, 2.2 auto- the daily driver, currently with a 2"/2" drop and some minor engine bolt-ons
1978 Impala 2-door, race 350/T350 - the new race car, in progress
1968 Chevy C10 longbed- 3/5 drop, currently undergoing a heart transplant
ka_jd7and1 is offline   Reply With Quote
Old 06-13-2018, 12:45 PM   #4
kwmech
Gary
What he said, sounds like your truck may have come with a 6cyl originally
Old 06-13-2018, 01:08 PM   #5
mattfranklin
Good point. VIN code says 350 4bbl, but who knows what has been changed in the past 48 years by previous owners. Heck, I think I have a '67 gauge cluster in my '70 truck and there is even a wiper switch where the choke was supposed to be or vice versa.
Old 06-13-2018, 02:10 PM   #6
mattfranklin
Great suggestions, everyone. Thanks!
I think in the long run I will track down that 3/8" original style line. InlineTube didn't mention it among their products. It looked like LMC had it in stainless for only the 71/72 trucks. Not sure if that is ok or something will bite me on that.
In the short run I'll run some form of adapter. At least to get it running under its own power.
Old 06-13-2018, 07:46 PM   #7
GASoline71
GASoline71's Avatar
Inline tube has it... I have used them and they are good quality.
Part# CTF6702, 67-70 V8 1/2 & 3/4 ton front to rear 3/8" 2-pc, SS $85, OE STEEL $60
Gary
Old 06-14-2018, 01:31 PM   #8
mattfranklin
Gary
Excellent! Thanks!
This looks like regular steel.
https://www.inlinetube.com/_p/prd14/...?q=thunderbird
And the stainless version is...
Available at Classic Industries.
