Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
View Poll Results: How many of us would look at a "BIG TRUCK" Forum
I have one of these and would post/look ALL THE TIME! 142 28.92%
I don't own one but I would definitely look at a forum for something to drool over 323 65.78%
I don't care, probably wouldn't ever even take a peek. 26 5.30%
Voters: 491. You may not vote on this poll
Old 01-15-2015, 06:21 PM   #276
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: "BIG" truck forum C/40, C/50, C/60 and the like...
Originally Posted by Mack 63 View Post
So it appears there was a tach there stock, just changed out at some point?
maybe, that was the spot for a tach, and a lot of the big trucks had them.
here are some shots of a correct one, the early ones had the separate "brain" under the hood.
Old 01-15-2015, 06:24 PM   #277
jonzcustomshop
1961 crewcab
I messed up on posting the wheel pictures. The top is a later model 20 inch from a c50, below that is my 22.5 rear. Below that is the front 20 on the newer truck. I was wondering if there would be any advantage in swapping out to the smaller wheel, but I noticed the fronts don't match up, I'll post a pic of my front wheel
keep all your 22.5's the 20's are a split rim, and tire shops won't mess with them. there is also more choice in the 22.5 size, I picked up a set of those to replace the 20's on my 65.
Old 01-15-2015, 06:30 PM   #278
Mack 63
Great, thanks for the heads up guys! Very usefull info
Mack 63 is offline   Reply With Quote
Old 02-15-2015, 03:03 AM   #279
ClassicTVMan1981X
How many of the 1979-80 Chevy C70s and GMC C7000s were optioned with the 454 tall-deck V-8? This engine was dropped from the medium lineup after 1980 and would not return until 1999, when it was re-engineered as the "Vortec 7400MD" and had replaced the ubiquitous 366 and 427 V-8 engines in the then-current C and T series lines.
~Ben
ClassicTVMan1981X is offline   Reply With Quote
Old 01-12-2016, 12:49 AM   #280
captdrew
captdrew's Avatar
Originally Posted by LUV2XCLR8 View Post
There is a yard near me with a bunch of them
Old post I know. Do you know the name of the yard?
Or if they are even still there. Thanks
captdrew is offline   Reply With Quote
Old 03-14-2016, 05:46 PM   #281
Mikkel
I got a 67 gmc big block v6 5.0L that's past life was a tanker truck for the government I cut 7ft off and drop off a axle shorten it up and put a stepside bed on can't get pictures to upload
Mikkel is offline   Reply With Quote
Old 03-14-2016, 08:41 PM   #282
colgad
colgad's Avatar
Click on paper clip
Try uploading one at a time.
Choose the file and upload
Then post
Dave (colgad)
67 C50 longbed
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline   Reply With Quote
Old 03-15-2016, 07:21 PM   #283
bjp68
Hi I'm new to this board, I just got a 1963 c60 looking for some good ideas for lowering it mabey for a car hauler.
bjp68 is offline   Reply With Quote
Old 03-15-2016, 10:37 PM   #284
jonzcustomshop
1961 crewcab
check these guys out, they lowered dinos 66 c/60
http://websta.me/n/gsi_machineandfabrication
they did a small build post on the forum, but never showed front suspension or finished shots:
http://67-72chevytrucks.com/vboard/s...d.php?t=680783
here are a few grabs off the net:
Old 03-16-2016, 07:21 PM   #285
bjp68
Thanks that's cool
Old 04-11-2016, 09:27 PM   #286
MAXPWR
MAXPWR's Avatar
This from Dinos build. The cross member they widened and bagged.
MAXPWR is offline   Reply With Quote
Old 03-17-2018, 08:46 PM   #287
1971'Burb
Some day...1983 C60
Runs good but I'd like a 4l80e in place of the 4speed. Ran out of back burners so this project is in the freezer,
Crawl, walk, run, fly... what's next?
1971'Burb is offline   Reply With Quote
Old 03-21-2018, 02:08 AM   #288
7 Devils
7 Devils's Avatar
I just got a 55 GMC 370 Series 2.5 ton dump truck that was used as a farm truck. 270 I6 with 4 spd and pto. It still runs and hydraulics still work. I will be bringing it home in the next month or two. It snowed the night before I went to do the inspection...
Forgive my typos, big fingers and little Android digital keyboard....what a mess
06 GMC Sierra crew cab Z71 DD leveling kit, 34's, bumper, LED lighting. Still doing stuff to it.
67 El Camino Custom 300 Deluxe. In progress.
55 GMC 371 2 1/2 ton. Upcoming project.
7 Devils is offline   Reply With Quote
Old 04-06-2018, 05:03 PM   #289
darrellkershaw
here is my project. 1970 c50 . im looking for shop manual. need specs for bearings and bolt torq.
darrellkershaw is offline   Reply With Quote
Old 06-07-2018, 02:09 PM   #290
Unofornaio
Here is a couple of mine 68 C 40. I'd love to see a forum for theses truck. I'm having a hard time finding parts..any help would be appreciated GREATLY. I'm currently stuck trying to find wheel cylinders and brake parts. Any info or source for parts or cross reference of parts would be great.
Unofornaio is offline   Reply With Quote
Old 06-07-2018, 03:44 PM   #291
watahyahknow
watahyahknow's Avatar
oops
i got a job again and having fun at it too
idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real
i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts
watahyahknow is offline   Reply With Quote
Old 06-07-2018, 04:28 PM   #292
1971'Burb
Time for a newer rear end? Freightliner box vans(UPS/Fedex) use GM and modern diesel drivetrains.
Old 06-08-2018, 06:32 PM   #293
_Ogre
_Ogre's Avatar
i believe this is the forum for big trucks
shop air compressor timer
Old 06-17-2018, 10:08 AM   #294
colgad
colgad's Avatar
Still working on my 67 C50. Some day it will have real paint.
Cut the frame off behind the cab and grafted a 92 TopKick frame to get the 10 lug rear. Freightliner front axle narrowed 10". Disk brakes all around. 445/45's on the rear. Grafted front fenders onto the bed and added another set of running boards to complete the look.
Old 06-17-2018, 09:47 PM   #295
Mike Flea
Mike Flea's Avatar
I know there a few that don't like these and think it's a waste of a hauler, but I like it. Nice build. What color do you think you're going to paint it?
Mike Flea is offline   Reply With Quote
Old 06-19-2018, 07:19 PM   #296
colgad
colgad's Avatar
Orange and Black
Old 07-05-2018, 06:34 PM   #297
Mike Flea
Mike Flea's Avatar
Sweet!
Old 09-20-2018, 03:32 PM   #298
paulxjen
I just bought a C-50 at auction, it has a 307 crate engine with less than 5K miles but has been sitting for the last 10 years, the sellers put some gas in carb and it fired right up. It has a tilt bed and 2 speed rear end. I have little experience working on large vehicles, any advice on this project would be greatly appreciated. Especially the brake system, any upgrades or tricks to help stop better.
Things to work on first
Brakes
Fuel system (adding saddle tank)
Tires
Later work
Remove cab and make few rust repairs and paint
Have undercarriage sand blasted and painted
paulxjen is offline   Reply With Quote
Old 09-20-2018, 04:37 PM   #299
C10 - C90 Bill
C10 - C90 Bill's Avatar
Looks good.
Keep us posted on your progress.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
C10 - C90 Bill is offline   Reply With Quote
Old 09-20-2018, 07:21 PM   #300
watahyahknow
seems to be a solid truck from wat i see on the pictures
