Old 04-16-2018, 06:41 PM   #1
Mr.Orange
Battery wears down
hello, I have an 82 gmc c1500, 350 chevy, 4 speed auto. I am having a starting problem. When I try to start it, the starter engages and then the battery wears down in less than 10 secs or so, then the battery only has enough juice to make the solenoid click repeatedly and the battery has to be recharged..
Battery has voltage before cranking, then wears down during cranking. Battery terminals are clean. The headlights dim when cranking.
Can y'all give some direction on areas to check as to why this is happening?
Mr.Orange is offline   Reply With Quote
Old 04-16-2018, 08:00 PM   #2
franken
Re: Battery wears down
Start w/ battery voltage.
Old 04-16-2018, 08:21 PM   #3
mongocanfly
mongocanfly's Avatar
yep^^^ sounds like the battery
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-16-2018, 08:48 PM   #4
Bandit130
Bandit130's Avatar
You did not mention battery age. That may be the problem.
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is online now   Reply With Quote
Old 04-16-2018, 09:59 PM   #5
Mr.Orange
Just went out and checked out the battery. Was at 12.33v. Popped off the cell tops and each of the cells were a little bit low, so I refilled them to where they should be. Sticker on the battery says 12/16. It's a Duralast Gold (24S-DLG), 575CCA, 715CA@32*, 130RC.
Old 04-17-2018, 12:06 AM   #6
andyh1956
Do you have a load tester? Measuring battery voltage is not gonna help you find your problem.
andyh1956 is offline   Reply With Quote
Old 04-17-2018, 06:42 AM   #7
Dead Parrot
Check voltage with the engine running on fast idle. Should be around 14v. Then turn on some lights and see if voltage stays steady. Could be the alternator has partially failed.
Is the alternator OEM or an aftermarket "one wire" version? One wire versions get their voltage sense at the alternator instead of the junction block. Can make a difference if there is a voltage drop in the red charge wire from the main alt terminal to the junction block.
Could also be a warranty event on the battery.
Dead Parrot is offline   Reply With Quote
Old 04-17-2018, 08:46 AM   #8
cadillac_al
If it's that new take it back to the seller and let them test it. When they are out of warranty and weak we call them summer time batteries around here. 575 cca is one step above a lawn mower battery. They don't work so well in stubborn non efi v8's.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 04-17-2018, 08:54 AM   #9
rainamy
X2 on the 575cca..... I run 850 myself.
rainamy is offline   Reply With Quote
Old 04-17-2018, 11:46 AM   #10
truckin 79
I would check out the starter solenoid could be drawing a lot of amps. I have always used the cheapest battery on the 79 Trans Am and Truck with no problems in cranking, CCA is a selling ploy unless you live in Alaska or have a high compression engine. Is there a Autozone or Advance Auto near you? They can check the entire charging system while on the car. Be careful if the starter solenoid is bad you can burn up a good battery quickly, volts and amps are 2 different animals.
79 Chevy 2wd BIG10 350 TH400
truckin 79 is offline   Reply With Quote
Old 04-17-2018, 10:33 PM   #11
bilfman
bilfman's Avatar
It’s the battery, 100%
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
