09-20-2017, 07:45 PM | #1 |
65 chevy c10 rear coil spring
i installed new rear coil springs and trailing arm bushings with tracking arm rear end is offcentered by 1/2 anyone have any ideas why? adjustable tracking arm i see my only fix
09-20-2017, 08:46 PM | #2 |
Re: 65 chevy c10 rear coil spring
Check you track arm bushings
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
09-21-2017, 02:40 AM | #3 |
Did you get lowering springs or are they stock height ?
09-21-2017, 08:33 AM | #4 |
09-21-2017, 08:34 AM | #5 |
09-21-2017, 08:45 AM | #6 |
09-21-2017, 01:17 PM | #7 |
Is the truck complete or going together? Reason I ask is if all the weight is no on it it will be off to one side. Also it it is only a 1/4" off on the length. Mine was off a bit to one side with no load in the truck but when I used it as a truck it was pretty centered. Now that is has been lowered and has the long track bar on it it changes very little between unloaded and a bed full of mulch.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
09-21-2017, 03:57 PM | #8 | |
09-23-2017, 10:37 PM | #9 |
thanks for ideas ,i figured out why my rear end was off so bad , may sound kind of dumb but as i was asked about stock height, im thinking it is , but today it dawned on me, i added rear air shocks when i installed new trailing arm bushings and tracking arm i let air out of shocks to almost nothing and it is within 1/4 i think ill go back to set of gas shocks
09-25-2017, 07:28 AM | #10 |
The short track bars move the rear a good bit as they travel. That is greatly improved with the long bars. As an added bonus it lowers the roll center to improve the handling.
Jimmy
