06-29-2008, 09:52 AM | #1 |
PROJECT 7DEUCE
Gas pedal question....
What set-up did you guys use for you gas pedal? Right now mine is mounted way up on the fire wall and makes it difficult to drive so i ordered a eliminator pedal and cable assembly was just wondering if anyone else has this set-up?
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
06-29-2008, 10:33 AM | #2 |
Re: Gas pedal question....
I used the lokar with the cable linkage kit................
06-29-2008, 11:23 AM | #3 |
Check out Chevy Duty, they had a stock one for V8,for the 5-6-7 truck and inexpensive
06-29-2008, 12:33 PM | #4 |
Hello prostreeter 58
If you would show us a picture of the brake pedal and master cylinder set upand any info you r truck looks good and I like the view from the top of the brake setup Gene Sharp |
06-29-2008, 01:37 PM | #5 |
PROJECT 7DEUCE
Very nice thansk... Thats what I was looking for..
