Old 08-07-2018, 12:37 PM   #1
jayoldschool
Moderator
Need help ASAP with 63 vent window reinstall
Putting vent windows back in on buddy's 63. Fresh paint, new rubber. Need to know about the rubber that surrounds the frame that goes against the door. Does it pull out (with cord) to overlap the door metal like on a windshield? Or, does it simply butt up inside the door frame?
Thanks, need to get these in to finish reassembly of the door today.
jayoldschool is offline   Reply With Quote
Old 08-07-2018, 07:57 PM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Need help ASAP with 63 vent window reinstall
The vent window frame seal goes to the inside of the channel...
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 08-07-2018, 08:55 PM   #3
jayoldschool
Moderator
Well, we went ahead and pulled it with wire to overlap the sheetmetal. Like installing a windshield gasket. Looks great, and will keep the water out.
Old 08-07-2018, 09:13 PM   #4
vin63
vin63's Avatar
Unfortunately, it won't keep the water out, and it will be pretty noisy driving down the road.
