11-08-2008, 05:55 PM | #1 |
Urethane over lacquer
I'm getting ready to paint my firewall and have it all cleaned and sanded. I bought single stage urethane and was planning to spray it over the factory finish that I assume is lacquer. Will there be any problems with this? I hope to do this on the rest of the truck as well.
11-08-2008, 06:41 PM | #2 |
Re: Urethane over lacquer
"In general" you can spray nearly anything over lacquer, but you can't spray lacquer on top of anything else.
It will be ok as long as you have it clean of any oil residue and sanded adequately. The firewall/under-hood is fine, but I don't think I would do it on the outside of the body though. The lacquer could still "check" (crack) under the top coats. It would be subjected to the sun on the outer body. |
11-08-2008, 06:53 PM | #3 |
what would I have to do to spray it on the outside? I would really like to not have to strip the paint.
11-08-2008, 08:23 PM | #4 |
I don't think they ever put lacquer on a truck
11-08-2008, 08:25 PM | #5 |
what did they come with from the factory?
11-08-2008, 08:29 PM | #6 |
older trucks would have enamel and then acrylic enamel,very late 80,s would be B/C
11-10-2008, 11:56 AM | #7 |
old original paint you'll be fine to spray over//firewalls make sure you've got all remnants of the grease pencil markings off the old finish
11-13-2008, 08:11 PM | #8 |
be carefull with urethane over lacquer. I learned the hard way on my 71 vette. after 6 months the areas that still had lacquer on the body caused the paint to have tiny bubbles. to avoid this make sure to seal it with a quality epoxy primer
1971 Corvette convertible 454@ 525 hp 1936 Chevy Truck street rod 1952 Chevy truck hot rod build http://www.killbillet.com/showthread...2-Chevy-Cut-up 1964 F 100 custom street rod http://www.ford-trucks.com/forums/12...mark-viii.html 1950 custom Chevy Truck Last edited by 50adrod; 11-13-2008 at 08:12 PM. |
11-14-2008, 07:53 PM | #9 |
Robert Newland Auto Collision Instructor ASE Certified Auto Collision PPG Certified Automotive Painter 1971 Chevy C10 Short Bed 350 Four Bolt Main / 350 Turbo |
