Old 03-24-2014, 01:32 PM   #1
Sean C
66' 3 Point Seatbelts_B Pillar Plug...
Has anyone dealt with these plugs before? From what I've found, some of the 66's have the plug in the B pillars and some have the threaded nut. I'm not totally sure how to remove this plug so I can get my belts in. Any info would be greatly appreciated!!
Sean
Sean C is offline   Reply With Quote
Old 03-24-2014, 01:57 PM   #2
1963c-10
1963c-10's Avatar
Re: 66' 3 Point Seatbelts_B Pillar Plug...
check out this thread...may help some
http://67-72chevytrucks.com/vboard/s...d.php?t=459298
1964 Short bed trailer
Old 03-24-2014, 01:58 PM   #3
Sean C
I got it! Couldn't tell if the plug was metal/if there was a threaded nut on the other side and didn't want to damage anything, but I pried the darn thing out and discovered those BEAUTIFUL threads...I'll post up pics of my extended weekend project
Old 03-24-2014, 02:00 PM   #4
1963c-10
1963c-10's Avatar
Cool...glad it worked out.
Old 03-24-2014, 02:02 PM   #5
PGSigns
PGSigns's Avatar
Post a pic of where it is at with a measurement or two if you can. My 66 has been upholstered on the full interior and I have belts coming. This will help me find it if it has one before I pic a spot for the new hole.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-24-2014, 02:48 PM   #6
1963c-10
1963c-10's Avatar
Here you go
Old 03-24-2014, 08:58 PM   #7
PGSigns
PGSigns's Avatar
Thanks. Well looks like I wont have a problem hitting the old hole. Looks lie the used it to center up the hole for the speaker.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 12-24-2017, 12:29 PM   #8
raidmagic
raidmagic's Avatar
Older thread, what are you using for shoulder belts? Also what's behind the hole? I'd like to add shoulder belts and am thinking about a 1/4 plate with a nut welded to it put in from behind.
raidmagic is offline   Reply With Quote
Old 12-24-2017, 02:12 PM   #9
The Rocknrod
Moderator
The Rocknrod's Avatar
I can't seem to find the thread, but it shows how to make a 3 point B-Pillar mount.
Old 12-24-2017, 02:18 PM   #10
AcampoDave
AcampoDave's Avatar
If you don't feel like making it, you can buy everything you need from Juliano's interior products.
AcampoDave is offline   Reply With Quote
