Old 06-09-2019, 12:21 AM   #1
72longstepper
Rear upper bracket
Snapped one and will be replacing both. Does it matter which of the two holes in the upper bracket I use to install the new studs? Leaf spring standard height and using plain old Monroe gas shocks for replacements.
72longstepper is offline   Reply With Quote
Old 06-14-2019, 10:31 AM   #2
SCOTI
SCOTI's Avatar
Re: Rear upper bracket
I would use the hole that keeps the shock as upright as possible. The more it lays over, the less effective a shock is at its job.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-17-2019, 01:09 PM   #3
69gmcc10
69gmcc10's Avatar
i'm with scoti. Move the studs to the rear hole and the shock should work "better." If I would have kept the leaf spring rear in my truck I had planned to move the stud to the rear hole anyway.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 06-17-2019, 11:52 PM   #4
72longstepper
OK TY for replies.
Old 01-17-2020, 02:14 PM   #5
Mike_The_Grad
Mike_The_Grad's Avatar
How did it work out for you? Did you use the rear hole of the bracket for your shock stud? I have leaf spring rear also and was wondering about the rear location to mount the shocks, if it will work.
1972 C/10 LWB - Mine
1964 C/10 LWB - My Dad's
Instagram: Mike_The_Grad
Mike_The_Grad is offline   Reply With Quote
Old 01-28-2020, 12:38 AM   #6
72longstepper
Sorry about late reply----I just ended up drilling out broken stud and putting new stud in same place.
