Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical
Old 11-08-2020, 12:23 AM   #1
SunSoaked
SunSoaked's Avatar
Clutch safety switch-
I converted my 85 from auto to manual. The new clutch safety switch has two female plugs. One is for the starter interrupt,. not sure what the other is for but it doesn't matter. Anyway, there's no way to use female connectors on it, the male spades are embedded in the plastic plug.
Anybody have a lead on this or able to snip me off the plug from a manual trans equipped square body?
Here's some photos. It's the one nearest the firewall or on the left in the pic.
SunSoaked is offline   Reply With Quote
Old 11-14-2020, 11:15 AM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Clutch safety switch-
Have you had any luck with this yet?
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 11-14-2020, 11:33 AM   #3
SunSoaked
SunSoaked's Avatar
Yes. A member on another site has a 89 v30 he's parting out. Someone bought the pedal assembly and I was able to get the factory plug with pigtail.
Thanks VetteVer. If you know of a source of oem plugs that would be nice for future reference.
Old 11-14-2020, 12:38 PM   #4
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Since you had the automatic trans wiring harness you wouldn't have had the harness plug so I know your dilemma and I was going to suggest mounting a brake light switch and hard wiring the harness neutral switch wiring into it. Good that you found what you needed though.
Here is a good source for any parts for our trucks.
https://www.partsgeek.com/ymm/1985/c...op&scat=clutch.
Second row, far right. It;s your switch but no connector.
VetteVet
Old 11-14-2020, 02:00 PM   #5
The Rocknrod
Moderator
The Rocknrod's Avatar
Contact these guys maybe you'll get lucky - https://www.repairconnector.com/
Old 11-14-2020, 02:51 PM   #6
VetteVet
Msgt USAF Ret
VetteVet's Avatar
This maybe it.
https://www.rockauto.com/en/catalog/...ector,neutral+
scroll down to neutral safety switch.
VetteVet
