Old 11-27-2020, 03:44 PM   #1
mike in mo
Front bumper mounted spare tire
Got a 94 k2500 with a slide in camper and getting to the under mount spare is a pain thinking of building a mount for the front bumper. Anyone done it ? Any issues to worry about? Any pics?
mike in mo is offline   Reply With Quote
Old 11-27-2020, 04:01 PM   #2
Re: Front bumper mounted spare tire
Only think I have heard of is the cooling/overheating possibility. The tire will block most of the air flow from going directly thru the radiator, so make sure you leave a decent gap between the spare and from of grill so air can get into the radiator.
1981 GMC High Sierra SWB Stepside
Board Vendors
It's scary when you start making the same noises as your coffee maker.
Palf70Step is online now   Reply With Quote
Old 11-27-2020, 10:29 PM   #3
Ironhorse
Ironhorse's Avatar
Used to see just such a spare tire mount style on the earlier square body trucks in the late 70s into the 80s. Was quite popular then with the amount of bed mounted cab over campers of the times. Good advice about the spacing out from the grill for air movement. Be sure you have a good radiator/fan shroud and proper fan/clutch and water pump. Don't see it much today but used to be quite prevalent on the road. Thinking welded braces and upright coming up off the front frame horns is the ticket. Good luck.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 11-28-2020, 01:08 PM   #4
1976gmc20
Yeah, I used to see them all the time and never heard of anyone having overheating problems, but it probably depends on the climate.
Did the original crank up mechanism fail? I'm not sure why some aftermarket outfit isn't making a heavy duty replacement? Or one could get the spare crank/winch off of a newer junkyard pickup and adapt it to the GMT400 frame.
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10
1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20
1977 Chevy C-10 Suburban; 1980 Chevy K-10
1989 Chevy K1500; 1991 GMC V1500 Suburban
2016 Chevy K2500 HD
1976gmc20 is offline   Reply With Quote
Old 11-28-2020, 02:04 PM   #5
mike in mo
Thanks guys I'm going to give it a try . My 79 g20 van has a front mount and dont run hot hope for the best I guess. No the factory stuff works but my camper hangs over the bumper so I can't get to the tire winch hole.
Old 11-29-2020, 12:59 AM   #6
Just call me Sean
Just call me Sean's Avatar
This is mine. I made it from a van tire carrier and bolted it to the brushguard. No cooling problems, this is Florida and I always pull a trailer with the a/c cranking.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 11-29-2020, 02:40 AM   #7
mrtoni
I have this one for 70ís Ford. Pretty simple design
mrtoni is offline   Reply With Quote
Copyright ©2000 - 2021, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
