11-25-2016, 09:26 PM | #1 |
Evolution Miter Saw Review
I thought I'd give my review for the Evolution Rage 2 Miter Saw in case anyone out there is considering buying one. I got mine a year ago, and I don't use it frequently, but I do use it heavily when I use it. Today I made upwards of 50 cuts in 1½" 1/8 angle, 1" square tube, 1/2 square tube, and 1X½" channel. The saw performed flawlessly, as it has every time I've used it. I've cut ½ inch plate with it and it's had no problem.
I did buy the dedicated steel cutting blade for it, but even so it was over $150 less than the nearest competitor. It makes clean cuts that need little or no cleanup before welding (probably what I appreciate most about it) and the cut ends aren't even hot. It's quieter than my old saw, which was an abrasive 10" saw, although when you're cutting steel "quiet" is a relative term, and I advise never cutting without hearing protection. The miter fence is sturdy, but it's definitely nothing fancy. The built-in clamp is functional but not great, but it does provide enough clamping force. Overall, I love this saw for how easy it is to use and how clean it leaves the cuts. I give it 4 out of 5 stars, the miter fence and clamp being the only reason I don't give it 5. |
03-01-2017, 04:28 PM | #2 |
Re: Evolution Miter Saw Review
Love one someday. I so hate the abrasive dust cloud saw, it sits and sits. Use my band saw mostly.
"I feel the need for speed!"... as soon as I am done with my nap. |
03-05-2017, 09:09 AM | #3 |
blood type; Retumbo
I've thought about a steel blade for my 12" 15 amp Ryobi saw
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
03-05-2017, 01:29 PM | #4 |
