Old 04-04-2002, 02:41 AM   #1
REPO1
Shortbox wanna-be.
REPO1's Avatar
Post T400 kickdown wiring question
I notice there are 2 wires that go to the switch on the intake to sense wide open. One is power I assume that comes from the fuse panel? The other is an orange wire that I think should be going down to one of the terminals on the tranny. Would I run a ground wire to the other terminal of the tranny? For whatever reason it is all missing.
Sylvan Lake, Alberta, Canada
1970 Chevy C20 Custom Camper
#s matching 402BB Turbo 400 trans.
Air conditioning, power steering, manual brakes.
73,600 Original Miles!!
(Add on 2000 more from raod trip!)
402BB Turbo 400 trans. (Slowly becoming a '70 shortbox 1/2 ton)
'71 Camaro SS 402/T400 resto
'97 Z28 (11.41@127MPH)
REPO1 is offline   Reply With Quote
Old 04-04-2002, 03:15 AM   #2
67 LWB
Post
you are close. there is a positive wire from fuse block that goes to one of the terminals on the switch and from the other terminal run a wire down to the kickdown solinoid on the drivers side of the tranny. sounds like you have 2 prongs. i cant remember which one is the right one maybe some one else will know.
good luck
'67 C10 LWB FLEETSIDE, WEAK 305 UNTIL I CAN GET THE 400SB REBUILT, TH400, 3.73 REAR
SALEM, OREGON
http://www.freephoto-i.net/browse.ph...e=DCP_0003.JPG
'67 C10 LWB FLEETSIDE, WEAK 305 , TH400, 3.73 REAR
COLORADO SPRINGS, CO.
67 LWB is offline   Reply With Quote
Old 04-04-2002, 03:26 AM   #3
RipMeyer
RipMeyer's Avatar
Post
The orange one is the kickdown that goes to the solenoid on the tranny.
RipMeyer is offline   Reply With Quote
Old 04-04-2002, 08:30 AM   #4
JimKshortstep4x4
Smile
You must have the double prongs on your transmission. The female receptor for that switch has a black wire and an orange wire
coming out of it, (black for ground, orange for power from the kick down switch). I would suggest that you obtain the plug because it seals the switch from the elements.
I believe that the power goes to the cross
or top of the the tee configuration and the
ground goes to the verticle of the tee that is formed by the two terminals.
Power to your kickdown comes from the ignition terminal on your fuse panel.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 04-04-2002, 10:06 AM   #5
REPO1
Shortbox wanna-be.
REPO1's Avatar
Post
Yup, its got 2 terminals on the plug on the side of the tranny. I guess I will try and find one at the wrecking yard, or maybe GM will sell a repair pig-tail I can use.
Thanks!
Reid
