07-16-2007, 05:39 PM | #1 |
Tank removal....
Anybody got a link for the fuel tank removal protocol for the square bodies?
75 Jimmy 4wd. Also, how much does the tank weigh dry, and how long y'all reckon it would take? Will probably be doing it by myself. Thanks SLIMJIM
1970 Chevrolet Blazer 2 wheel drive - SOLD Last edited by SLIMJIM; 07-16-2007 at 05:40 PM. |
07-17-2007, 06:40 PM | #2 |
www.73-87chevytrucks.com
Re: Tank removal....
It "might" weight 10lbs empty.
Unbolt the filler neck, if you can, remove the filler tube, remove the 2 rear straps and lower it down. Make sure the vent hose gets removed and the sending wire is disconnected before letting it hit the ground.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
07-17-2007, 06:48 PM | #3 |
The tank itself , empty, weighs maybe 30 - 35 lbs. I just had that done myself --- the mechanic removed the skidplate, then disconnected the fuel filler neck , the fuel lines and then the tank straps and it drops out. The mechanic told me the hardest part was removing the skidplate. the tank was a 31 gallon unit.
Procedure for mine was a little different because it had a fuel pump in the tank. It took an hour and a half ----- therefore i guessed it would have taken me 2 or 3 hours on my own |
07-18-2007, 11:48 PM | #4 |
Tonawanda 454
I had to do mine to replace the intank pump a few months ago and it had half a tank of gas (couldn't find a working siphoning kit)... it all worked out anyways, I just put a floor jack under it and slowly dropped it down, laid it on some 2x4s, replaced the pump and raised it back up... took me and my lack of experience about 1 full day (12 hours) of doing it.
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!! 04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011) In the past 30 years about 90% of Fords are still on the road, the other 10% made it home. ------------------- |
07-19-2007, 07:29 PM | #5 |
Thanks for the responses. Gotta do it soon.......
SLIMJIM
1970 Chevrolet Blazer 2 wheel drive - SOLD |
12-21-2009, 03:41 PM | #6 |
Ridin' Dirty
Did the tank on my 76 Blazer and I found that removing the rear bumper made it much easier to get at the tank strap bolts.
1978 C3500 Crewcab (Project) 1979 C2500 Crewcab (Driver/project) 1988 R2500 Crewcab (Driver) 1988 V3500 Crewcab 1988 R2500 Crewcab (Mint, Ex Fire Dept) 1968 Chev Suburban (4x4 conversion) LINK 1970 Chev C20 Suburban (driver/cruiser)LINK 2005 Impala (Incognito vehicle) 2004 Yukon XL Denali (Kid hauler) 1947 Case tractor Facebook Page(1000's of pictures of GM cars and trucks organized into albums) YouTube Channel |
