Old 05-23-2019, 07:39 PM   #1
Nima
Blue 67
Storing an auto transmission
Hi:
I got a good deal on a low mileage 4L60e transmission but I don't have time or all other parts at this point. What is the best way to store it? The fluid was drained. Will keeping it this way hurt the internal?
1953 GMC 3/4 ton: current project
1967 C20: 5.3 voretc with T5 conversion, 4 wheel 8 lug disc brake
1972 Nova: my 4 door sport sedan! 5.3 voretc + T5 conversion. drivable project, FUN!!
1979 Camaro Z28: 5.3 vortec conversion with build TH350: drivable project, Fun to drive
1992 Camaro RS convertible (Z28 clone): 5.3 conversion with build T5: on going project
2005 Silverado 2500, 4x4 Duramax, original owner
Nima is offline   Reply With Quote
Old 06-20-2019, 07:03 PM   #2
YoungPup1977
Re: Storing an auto transmission
Keep moisture out of the trans, store it in a dry place. They sell plastic plugs that fit on the output shaft/tail housing and leave the TC in the front of the trans. best of luck!!
YoungPup1977 is offline   Reply With Quote
Old 06-21-2019, 04:51 PM   #3
sweetk30
sweetk30's Avatar
i have a fresh reman 4l80-e that i had the local trans builder tear down and swap the tail shaft for me . he said for over 10 years old on a shelf in the shipping container it looked perfect inside .
so like said shelf it / plug it up / keep it fairly dry . when you do fire it up let it run a bit with the wheels off the ground after the fluid level is up to the mark and cycle it threw the gears no load on it . help get the clutches soaked in fluid if they drain off to much . otherwise run it .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
