Old 12-02-2019, 06:41 PM   #26
Dukk
Re: Where do I cut this fender?
Pardon my noobness - I see that the fender cup patch panel is too small (I mean how do they even DO that?!?) but what about buying a complete re-pop fender and trimming off the front piece? Is that a better fit?
Dukk is offline   Reply With Quote
Old 12-02-2019, 07:06 PM   #27
dmjlambert
dmjlambert's Avatar
Originally Posted by landarts View Post
Here is how I recently did this about two weeks ago on the 68 Second Chance Build. Had to add additional 1/2 of material on both sides of fender cup. One of the things I did that made it easier to work on was tack weld a small temporary piece of metal on the bottom so that it would not twist or change in size. You can see it in the first two photos.
Once you have that 1/2" wide cut open like that, what do you use to fill it in? Do you take a strip of sheet metal and bend it by hand to fit?
Old 12-03-2019, 06:42 AM   #28
Warrens69GMC
Warrens69GMC's Avatar
I would take a template and cut it out of the cup you just cut out, if its in good enough shape.
1969 307, t350
1950 Chevy Wagon
Warrens69GMC is online now   Reply With Quote
Old 12-03-2019, 10:24 AM   #29
Andy4639
Orignal Goof member
Andy4639's Avatar
Thumbs up Re: Where do I cut this fender?
This is what I'm thinking I'll do. Looks to be the easiest way and simpliest way of adding the patch.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 12-03-2019, 10:54 PM   #30
kaycee
kaycee's Avatar
So are you guys reporting these pieces of crap back to the vendor you bought them from? Surely there are better pieces around anyone checked out classic heartbeat
2001 Silverado K-1500
2005 FXDWG stage2
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60/3:36
kaycee is offline   Reply With Quote
Old 12-04-2019, 12:30 AM   #31
dmjlambert
dmjlambert's Avatar
I had a conversation with GMCPauls via email, because I trust that they know what's what more than most vendors. I was pleased with the informative and professional response: "The front fender cups only made by 1 manufacturer and have the same issues. A lot of fender cups aren't rusted out from front to rear of cup and on those we recommend just cutting out rusted portion then cut in to repair panel vertically to get the front or most commonly rear section needed to perform the repair. "
So, until somebody tools up a better part, the guidance folks are giving here in this thread make this thread something great to bookmark. Thanks to the experienced folks on this forum for helping us understand how deal with stuff like this and answering questions. I have not begun dealing with this area of my truck yet, but now I feel more confident for when I get to that part.
Old 12-04-2019, 08:34 PM   #32
Andy4639
Orignal Goof member
Andy4639's Avatar
Wink Re: Where do I cut this fender?
I ended up cutting the spot welds out of the cup and welding the whole cup into place and it looks like it worked just fine. Only time will tell when i go to align it up with the inner fender which I think will be fine. I can drill new holes. Dang I for got to take the pictures of it welded up!
I'll post them tomorrow night I guess.
Old 12-04-2019, 09:01 PM   #33
kingsolver72
10/30/19
kingsolver72's Avatar
Nice work!
kingsolver72 is online now   Reply With Quote
Old 12-04-2019, 11:28 PM   #34
Getter-Done
Getter-Done's Avatar
Looking Good.
84 Chevy K-20
paypal.me/Dwayne67CrewCab
Copyright ©2000 - 2019, vBulletin Solutions Inc.
