11-16-2021, 06:54 AM | #1 |
Removing retractable seat belt from '67
I'd like to keep the original seatbelts out of this parts truck because I like the color, basically. Is there an easy way to get at the bolt without wrecking the cover?
11-16-2021, 07:13 AM | #2 |
Re: Removing retractable seat belt from '67
Easy but not fast way would be keep conditioning the cover with vinyl softener,
For a few weeks. Link: https://www.leathermagic.com/vinyl-s...leather-magic/ If you are wanting to remove them in a timely manner you could drill the bolt out from the bottom if that section of the floor needs to be replaced. If drilling is your choice, Use Jobber drills or shorten a regular twist drill. Hope this helps.
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
11-16-2021, 07:19 AM | #3 |
Try using a heat gun or hair dryer to soften the cover at bottom.
11-16-2021, 03:44 PM | #4 |
Not quite what I was hoping but thanks guys.
11-16-2021, 03:58 PM | #5 |
Post Whore
There is the whole build the time machine of your choice, then go back 50 years and buy a new set plan.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
11-16-2021, 11:03 PM | #6 |
11-16-2021, 11:07 PM | #7 |
WD-40 does soften that stuff up also.
I would use Kitten Gloves to save what you have. Just my Suggestion.
