Old 02-23-2009, 10:00 PM   #1
Longstep70
Junior Member
Anyone run a side-exit exhaust with a step side bed?
I've seen a handful of trucks with a side-exit exhaust run under the steps exiting right before the rear wheel. Is anyone on here doing the same? I'm interested in clearance issues with the rear leafs or if anyone has run one with a 4-link and how it all fit together.
-Andy
Longstep70 is offline   Reply With Quote
Old 02-23-2009, 11:00 PM   #2
youngrodder
youngrodder's Avatar
Re: Anyone run a side-exit exhaust with a step side bed?
-Andy
I am running my exhaust out just before the rear fenders. I am not using the stock frame but it is a 4 link. The last running board braces forces you to move the exit point of the tail pipe toward the front more then I would have liked.
I used stainless Z-28 rectangle exhaust tips and I notched the running boards so that I could tuck the tip up tight so the tip follows the same thickness as the running board. Since mine is only a few inches from the running boards touching in the back when aired out I could not just hang the tips below the running boards.
Marc
youngrodder is offline   Reply With Quote
Old 02-23-2009, 11:50 PM   #3
JELLY
JELLY's Avatar
Marc
I was going to do the same on my truck to have more room for the air tanks, compressors, and gas tank without the mufflers taking room. Where do your pipes go outside the framerails?
JELLY is offline   Reply With Quote
Old 02-24-2009, 02:21 AM   #4
eventytoo
Marc
Do you have any pictures of this?
eventytoo is offline   Reply With Quote
Old 02-24-2009, 09:02 AM   #5
youngrodder
Jelly-- Mine will drop below the frame rail and exit just infront of the last running board brace. Again I am not using the stock frame, so it might be different then yours. I hid (2) 3-gallon storage tanks, (1) compressor and my valves under the bed. The floor of my bed was also raised a few inches to provide enough room for a notch and hinding of air ride STUFF.
My truck is blown apart at the moment getting ready for paint. I could only take a picture of the notch in the running board with the exhaust tip temperarily set in place.
Marc
Old 02-24-2009, 09:54 AM   #6
b00sted
b00sted's Avatar
Check your local laws for this.. I know here in GA we have a law requiring the exhaust to exit beyond the rear axle for passenger vehicles..
Or maybe it is a local ordinance.. With that said I am going to tuck my mufflers up within the lines of the frame rails and then have them turn down behind the rear fender at the rear... Going to be tight with me planning on laying frame but I think I can work that out..
1949 Chevy 408 CID stroker 6.0l with a few add ons, 4l80E, 4 Wheel Disk Brakes and a set of GT35 going on soon.
b00sted is offline   Reply With Quote
Old 02-24-2009, 12:58 PM   #7
56chevy1300
56chevy1300's Avatar
My mechanic told me I can run my exhaust under my rear axle...does that make sense? Doesn't really to me but I'll wait and see.
56chevy1300 is offline   Reply With Quote
Old 02-24-2009, 02:00 PM   #8
Longstep70
Junior Member
Marc
This is what I had in mind for my 59. I figured i would keep the exhaust out of the back so I'll have less hassles with the gas tank and panhard bar and air stuff when I finally get around to deciding where everything will fit. What mufflers are you using?
Anyone have any pics?
Old 02-24-2009, 04:22 PM   #9
youngrodder
No pics yet. As I mentioned my truck is blown apart at the moment for paint.
Because I am using a g-body frame. My frame and gas tank coupled with the fact that I am using air ride limits me from going all of the way out the back or side.
My exhaust system will be in 2.5" SS. I went with SS flowmaster I think 40 series. They are not suppose to be very loud.
I have some of the pipe bent but I need to have some help where it drops down from my headers.
Marc
Old 02-24-2009, 07:35 PM   #10
Longstep70
Junior Member
Its a little hard for me to do any more than just eyeball stuff since I ripped off the bed and rear leafs on my truck too but it seems that the tips should exit somewhere right around the place where the front spring hanger is located on the stock suspension. That's not far off the spot I'd likely be mounting the front of a 4 link setup so it looks like I'll probably be clear for running it out that way and not hanging up on the suspension. The stock '59 frame itself seems to offer plenty of room to fit the exhaust tubing in between the bottom of the rocker and step and the underside of the frame.
Old 02-24-2009, 07:42 PM   #11
OrrieG
OrrieG's Avatar
You can, but I have always ran mine over the rear or dumped it in front of the axle. I don't like stuff hanging below the axles or even frame rails for that matter. Sounds like the mechanic doesn't want to mess with it.
Old 02-24-2009, 08:56 PM   #12
youngrodder
Post Re: Anyone run a side-exit exhaust with a step side bed?
Old 02-25-2009, 01:20 PM   #13
56chevy1300
It was his suggestion as we talked about alternatives to running side exhaust or cutting a hole in the bed. I guess he's done this before with some lowrider cars and his own merc lead sled.
Old 02-25-2009, 01:34 PM   #14
1-ton of fun
polishing a turd
1-ton of fun's Avatar
i am pretty sure that is just has to exit past the passenger compartment. my 2003 ford lightning had the stock exhaust exiting in front of the rear tire, and i didn't think they were not legal for use in GA.
i had a problem getting my mustang inspected with dumps in front of the axle, because it didn't go to the perimeter for the car away from the passenger compartment, that is probably what you are talking about, or something similar
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
