Old 03-05-2013, 10:06 PM   #1
Hardesty454
Hardesty454's Avatar
T1I08TLM - Can you decode this!?
Ok, game time people. Who can decode this block I.D.
T1I08TLM
GO!
Rob
1971 c10 - ground up in progress
Tripp's Speed Shop Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=589750
Hardesty454 is offline   Reply With Quote
Old 03-05-2013, 10:11 PM   #2
chevyman91
Re: T1I08TLM - Can you decode this!?
T I believe is tonawanda n.y. which is the plant it is built as for the rest I have no clue
chevyman91 is offline   Reply With Quote
Old 03-05-2013, 10:14 PM   #3
Hardesty454
Good start!
Rob
Old 03-05-2013, 10:15 PM   #4
chevyman91
1969 Corvette 427 390 Mt HP that's what I found on the suffix code
Old 03-05-2013, 10:18 PM   #5
chevyman91
I'm thinking assembly date of January 8, of 1969 not 100% on that though
Old 03-05-2013, 10:26 PM   #6
Hardesty454
Where did you find the code for this answer!?
Rob
Old 03-05-2013, 10:28 PM   #7
chevyman91
I looked up the suffix code (lm) and the rest I just know took awhile to come back to me
Old 03-05-2013, 10:29 PM   #8
chevyman91
Here's a list of suffix codes http://www.nastyz28.com/gm-chevy-cod...-suffix-14.php
Old 03-05-2013, 10:32 PM   #9
Hardesty454
So the suffix code isn't "tlm". Just lm?
Rob
Old 03-05-2013, 10:34 PM   #10
chevyman91
That I'm not sure about didn't even see the t there
Old 03-05-2013, 10:36 PM   #11
chevyman91
Here's the right one sorry bout that TLM 1972 Truck 402 210 400 L-47 AR, 10, 20
Old 03-05-2013, 10:36 PM   #12
chevyman91
http://www.nastyz28.com/gm-chevy-cod...-suffix-15.php
Old 03-05-2013, 10:39 PM   #13
Hardesty454
Arrg. I see that now. You had me excited for a second. This is my engine in my 71. I was told it was a 454. Decided to check it out myself. Guess its a bit smaller than I thought.
Still a Chevy!
Rob
Old 03-05-2013, 10:43 PM   #14
SS Tim
SS Tim's Avatar
Tonawanda, November 08th, 72 Truck L47 402/210 C10-20 w/AR BBC or maybe a 76-77 Truck LM4 400/175 SBC.
Without a casting number and date code this is kind of moot and a waste of time.
SS Tim is offline   Reply With Quote
Old 03-05-2013, 10:45 PM   #15
chevyman91
Ya it is still a really good engine though. I haven't messed with the BBC that much but I believe you can stroke the 402 using a 454 crank Nanking a 440 c.I.
Old 03-05-2013, 10:50 PM   #16
Hardesty454
Well someone's a negative nancy.
How about I grab the serial number for ya.
Rob
Old 03-05-2013, 10:58 PM   #17
chevyman91
Ss Tim not arguing with you but why would it be november
Old 03-05-2013, 11:03 PM   #18
Hardesty454
Serial: 8999280
Rob
Old 03-05-2013, 11:05 PM   #19
Hardesty454
I lied!
3999290...
Rob
Old 03-06-2013, 09:34 AM   #20
bruceman1968
bruceman1968's Avatar
Chevyman91, The number given was T1I08TLM,
The I is incorrect, this is easy to tell cause there are no letters that would be in that spot, only numbers. So either it's a miss stamp or a miss read. Either way the most likely is a 1 misread as a I. So the code becomes T1108TLM
T= Towanda
11= November
08= 8th day of Nov.
TLM= 3 different motors depending on the year. With casting number 3999290 it narrows down to one motor, 72 Truck L47 402/210 C10-20 w/AR BBC (just like Tim said) Also it should have a automatic transmission. (M49)
It would be nice to see the date code, as a double check on the year. (I also have a 71, 402 listed)
CHEVY/GMC VIN DECODERS
bruceman1968 is offline   Reply With Quote
Old 03-06-2013, 10:05 AM   #21
bruceman1968
Just did some more research, 3999290 could be 68-72 402/396, so we need the date code to see if you have the 71, 402 310hp or the 72 402 210hp.
The 71 motor could have a auto or manual trans. The 72 motor was a auto. I'm betting on the 71 as the 72 was a prob. a car motor, although some references list it as a truck motor.
Check the date code for a definitive answer. I'm betting the date code starts with a K and ends with a 1. Should be 2 numbers in-between.
Old 03-06-2013, 04:51 PM   #22
chevyman91
Bruceman1968 thanks I figured it was miss read just guessed the month though thank you
Old 03-06-2013, 05:27 PM   #23
Hardesty454
Could swear that's an I.
Rob
Old 03-06-2013, 05:30 PM   #24
Hardesty454
Where is the date code?
Rob
Old 03-06-2013, 05:56 PM   #25
chevyman91
Its possible it might be a mis print usually one or two letters then four numbers then two or three letters
