01-21-2018, 11:35 PM | #1 |
Cutting up 65 cab
Cab is rusty in all the usual places, but if you happen to need an uncommon piece or section I may can help you out. I just don’t want to scrap anything that someone may be able to use. $15.00+shipping per section. I’ll gladly take pictures of anything you need, if you see any thing else of interest just ask. I will probably not be able to cut any areas until weekends. Thanks for looking!
01-21-2018, 11:40 PM | #2 |
One foot in front of the other
Re: Cutting up 65 cab
Sail panels?
01-22-2018, 12:22 AM | #3 |
01-22-2018, 12:59 AM | #4 |
can u post a pic of the center hump?
thanks
1963 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon 2008 Corvette convertible |
01-22-2018, 01:03 AM | #5 |
how bout both A pliars? can you cut the whole section from the bottom hinge hole area down. including both inside and outside the cab?
01-22-2018, 01:12 AM | #6 |
all this area.
01-22-2018, 09:32 AM | #7 |
Dash ?
01-22-2018, 11:49 AM | #8 |
Absolutely. It’s not perfect. There is some rust at the seam where the rocker meets the pillar. The kickpanel area inside is non existent.
01-22-2018, 11:59 AM | #9 |
01-22-2018, 12:01 PM | #10 |
01-22-2018, 03:09 PM | #11 |
01-22-2018, 03:57 PM | #12 |
01-22-2018, 08:30 PM | #13 |
not enough hours in the day
I'd take the center section of the dash. How much to ship to zip 68924?
65 K-10 Short Step 68 C-50 70 K-5 85 K-10 & piles of spare parts |
01-22-2018, 10:34 PM | #14 |
While not completely hacked up, the radio hole has been trimmed about an 1/8” see pic. If this isn’t a deal breaker tell me how much of the dash you want and I’ll get you a quote.
01-22-2018, 11:16 PM | #15 | |
I may still be interested pending pics when you get the time. My email is dwanepowers@att.net if that is easier. |
01-22-2018, 11:47 PM | #16 | |
The passenger side one is in better shape than I remember. It’s straight, but does have pretty deep scratches around the bottom. $30.00+shipping? Edit: I’m wrong there was a third sail panel, that was different and butchered. The one in the cab was the right style but was cut up as well....still gone eitherway. Last edited by Mack B; 01-22-2018 at 11:54 PM. Reason: Turrible memory |
01-23-2018, 12:18 AM | #17 |
Thanks, but the best I could do would be $25.00 shipped. If the rectangular brackets that are on the cab are there, I would do go $30 shipped for the brackets and the one sail panel.
01-23-2018, 12:19 AM | #18 |
would u b willing to cut out & ship the center hump?
01-23-2018, 12:37 AM | #19 |
Yes sir, the pic didn't show up as sharp as I hoped. The area under the gas pedal has rusted through, the passenger side is soft in that area as well. If those areas don't matter to you, just show me where you want it cut.
01-23-2018, 12:41 AM | #20 |
I need the brackets for my project, but I will get the panel to your door for $30.00
01-23-2018, 12:54 AM | #21 |
Appreciate ur help on this. The easiest way would be from the open seam to where it ends under the seat. On the sides if u could cut it where it meets the flat floor area on both sides that should work. LMK if that isnt clear & what u need for the patch.
Thanks Scott
01-23-2018, 03:20 AM | #22 |
Interest in big back window section, condition and pics of it.
What price do you want? Les |
01-23-2018, 07:35 AM | #23 |
I want the Whole dash from door to door
01-23-2018, 09:22 AM | #24 |
Need bracket and pedals for the brake and clutch. Zip code is 54935
01-23-2018, 09:37 AM | #25 |
I think I can work with that. I'd take from the instrument panel opening to the glove box opening and a few inches on the top. Kind of like this, a couple more inches to each side would be good.
