04-18-2023, 04:55 PM | #1 |
Junior Member
83 12 Bolt Posi in a 72?
Hoping someone can help me figure this one out. I found a rear end for sale said to be from an 83 c10 with 12 bolt posi and 3.07 gears. Should it be compatible if I were to swap the diff into my 72 1/2 ton rear end? Stock 12 bolt with 3.07 open diff and 30 spline axles. New posi units are typically described as being 64-82 but I haven’t found what the difference is with 83+. Thanks in advance!
04-18-2023, 05:03 PM | #2 |
Junior Member
Re: 83 12 Bolt Posi in a 72?
Pic for reference
04-18-2023, 07:22 PM | #3 |
Far as I know they dhould work as long as you use everything from thenewer unit. As long as they are both truck rears, you should be good. Car to truck are not all interchangeable but I do not know much about car 12bolts.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 04-18-2023 at 07:32 PM. |
04-18-2023, 10:07 PM | #4 |
I wonder if that is actually 1983 rear end. The Weld looks suspect, so maybe it was swapped in from an older truck. Is there a date code on the pumpkin casting similar to the one in this photo. The letter is the month, the first number group is the day, and the last number is the year.
04-18-2023, 11:53 PM | #5 |
If the reference pic is the 12 bolt you're looking to purchase, yes, the posi should work in your stock 72 rear
Christian Carpenter 1963 C10 - Frankentruck 283, 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
04-19-2023, 08:51 AM | #6 |
All about them K’s
I don’t think the 12 bolt truck rear was available past 82. They began phasing out in the late 70’s/very early 80’s in favor of the 8.5” 10 bolt and 9.5” 14 bolt SF. Someone likely swapped that one in at some point. My ‘57 is on an ‘88 K5 (yea I know it changed to the R/V series by then) frame and it also had a 12 bolt swapped into it as well from a mid 70’s blazer. It’s been that way since I bought it in ‘05.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
04-19-2023, 11:15 AM | #7 |
I didn't think 12-bolts were available in trucks newer than 1972. Later 1/2 ton trucks used the 8.5" 10-bolt as standard.
Well, I see that Rock Auto sells several parts and kits for 1973 8.875" diffs (12-bolt I assume), so it must have been standard on trucks with higher GVWR. Your biggest issue, IMO, is the type of springs used -- leaf or coil.
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
04-19-2023, 07:12 PM | #8 |
Junior Member
Thanks all! It's making sense now.
04-22-2023, 05:35 PM | #9 |
Trucks used the 12 bolt through 1982. The pinon in the 12 bolt truck was smaller than the 12 bolt car.
04-22-2023, 08:56 PM | #10 |
You're right. I just read in my 1982 shop manual that 10-30 series trucks used 7 different rear axles, categorized by ring gear diameter. They were 8.5" (10-bolt), 8.875" (12-bolt), and all the way up to a DANA 10.5".
My 82 C10 had the 8.5" 10-bolt. I suspect a step-up or two in GVWR got you the 12-bolt as part of the package. Maybe even in a C10.
04-24-2023, 08:07 AM | #11 | |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
04-24-2023, 09:51 AM | #12 |
I read through his first post too fast, and didn't catch that all he wants to do is swap in the posi carrier! I would add that he should check the clutch discs for wear.
Good tip on keeping ring and pinion pairs together.
04-24-2023, 10:21 AM | #13 |
I agree, I didn't want to add to the confusion by having him dismantle a posi unit. There were so many configurations of clutch discs it's hard to say how many of what kind of frictions and steels that unit has. The test for a posi is done when the diff is fully assembled and the axles and wheels are on. Jack up one side and measure the torque it takes to release that wheel...I'd just look it over good, make sure no discs are missing or broken. Check the springs and plates for breaks or cracks. Use a pair of Channel Lock pliars to compress the spring plates...
04-24-2023, 12:57 PM | #14 | |
My truck's 12-bolt has an Auburn cone-type diff that I installed over 20 years ago. It still lays down two strips of rubber, and doesn't chatter in turns, but doesn't really get much abuse.
04-26-2023, 05:24 PM | #15 |
I also have a question. I have a 67 gmc leaf springs and I’m wanting to swap out the 12 bolt for a 80’s 10bolt . I’m thinking it should mount right up but I really don’t know. I’m hopeful that someone has done this and can share some wisdom. Thanks
Posted via Mobile Device |
04-26-2023, 06:36 PM | #16 |
All about them K’s
It’s not going to be bolt in, the spring perch widths are different between the two as well as the shock mount locations. You will have to cut the old perches and shock mounts off and weld new ones on.
