Old 09-17-2016, 05:58 PM   #1
GSP7
Who's running Chevorn Delo in their motor
Just wondered if anyone is running Delo oil in your rebuilt vintage motor for the good zinc/phosphorus content which protects against wear
Delo LE 15-40 , zinc-.13, phosphrous .12
the old Delo multigrade(not LE) 15-40 , zinc- .15, phos.- .14
Most the new low emission oils the highest content is zinc .08 or less, phos .77 or less. Less for synthetics and syn/blends
Valvoline ZR1 racing oil is zinc 13-14, phos. .12-.13
Brad Penn oil is zinc .15, phos .14
'81 K20 Silverado ,
'99 Dodge Cummins 4x4
Pinstriping-Lettering-Specialty Painting
https://www.instagram.com/ricksspeedandcolor/
GSP7 is offline   Reply With Quote
Old 09-20-2016, 12:45 AM   #2
'63GENIII
'63GENIII's Avatar
Re: Who's running Chevorn Delo in their motor
I ran Delo in the 396 with flat tappet hydraulic lifters for a few years with no problems.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 09-20-2016, 05:59 AM   #3
mongocanfly
A long long time ago I used shell rimula straight 30w..ran that a few years and then switched to delo straight 30w...ran that in all my trucks and tractors for years and years..one of those trucks had 285k miles another had 235k and a few others up around 200k when I got rid of them..never had any internal engine problems...absolutely no complaints..but now I'm a believer in synthetic so that's what my stuff gets now..
mongocanfly is online now   Reply With Quote
Old 09-24-2016, 11:11 AM   #4
B. W.
B. W.'s Avatar
Have been running Delo since the 70's in fleet applications & personal use, both straight weight & multi-vis, everything from small to big. Good oil, can't go wrong with it. All the commercial grades still have a fairly high zinc content but they are reducing the zinc amounts also. Our oil options with flat tappet motors are becoming fewer & fewer. At this point we basically have 3 options:
1. run commercial grade oil (diesel grade)
2. use a boutique brand (redline, royal purple, amsoil, etc)
3. use a zinc additive
We still have to monitor content because, just as you pointed out, the Delo LE has less zinc than the old. Bob's the Oil Guy is a great web sight that has more info/data on oils than you'd ever want to know. Some of it is dry reading but very insightful. When I have insomnia that's what I read! I was in fleet maintenance for years, now I own a quick lube, tire & repair shop. I work on a lot of older rigs/ classics / hot rods so I am forced to stay up with the zinc content in oil - boy, that sounds boring!
B. W. is offline   Reply With Quote
Old 09-24-2016, 06:26 PM   #5
GSP7
I actually ordered 2 bottles of Zddp-plus, But,
I instead I'm going to run Delo. I already use Delo in my Dodge Cummins 4x4
Its only about $12.50 a gallon at walmart
B.W. I sent you a PM
'81 K20 Silverado ,
Old 09-24-2016, 07:33 PM   #6
mongocanfly
I meant to add to my above post that I still run delo 400 30w in all my tractors..
Old 09-26-2016, 05:42 PM   #7
fun in dirt
fun in dirt's Avatar
I do - 15/40 & Wix filter!
'72 Blazer "The Bucket" http://67-72chevytrucks.com/vboard/s...d.php?t=433190
'55 Chevy in progress gasser build https://www.trifive.com/forums/showthread.php?t=173938
'01 2500 Suburban...party wagon
'06 3500 Duramax ...tow truck
'06 Silverado SS...DD
'07 Classic 1500...DD
Gone but not forgotten:
'69 Pro Street Chevelle http://www.chevelles.com/forums/showthread.php?t=332541
'86 M1031 CUCV http://67-72chevytrucks.com/vboard/s...d.php?t=553619
fun in dirt is online now   Reply With Quote
Old 09-29-2016, 04:42 PM   #8
GK10
GK10's Avatar
I run straight 30W in my Boat 7.4 liter for the last 20+ years
GK10 Gary
GK10 is offline   Reply With Quote
Old 10-15-2016, 09:34 PM   #9
El Dorado Jim
I have been running delo 400 15/40 in all my vehicles for over 15 years , all gas engines, have had good luck with it...
El Dorado Jim is offline   Reply With Quote
Old 01-29-2017, 02:29 PM   #10
Redcap
20 years on Delo 400 (mostly in 15w-40) in everything. Wix filters too.
'77 K35 - 454, SM465/NP205, 4.56 D60/14bFF
Redcap is offline   Reply With Quote
Old 01-29-2017, 08:27 PM   #11
68panelman
68panelman's Avatar
Running 15/40 rotella in all my vehicles and thinking of a switch to Chevron delo. Anyone know how they compare to each other?
68panelman is online now   Reply With Quote
Old 01-29-2017, 08:38 PM   #12
El Dorado Jim
I run delo ,I buy it at Sam's club...
Old 01-29-2017, 08:40 PM   #13
68panelman
68panelman's Avatar
Price wise they're the same, I mean compare as far as quality/which is better?
Old 01-30-2017, 10:42 AM   #14
FBD guy
Internal engine failure due to wrong brand/type of oil is rarely a problem in our vintage trucks...in my opinion. All the additives and such are a waste of money, again my opinion only.
This is only from my experience and observations from having been in the automotive business for many years and having owned many many Gas and Diesel engines.
57NAPCO is online now   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions Inc.
